Correct usage of Ampère's law for calculating B-field outside parallel wires?
  • Thread starter Thread starter papercace
    Ampere's law Law
The discussion revolves around the application of Ampère's law to calculate the magnetic field (B-field) outside two infinite parallel wires carrying equal but opposite currents. The initial attempt to use Ampère's law resulted in a B-field of zero, which is incorrect, as the enclosed current is zero due to the opposing directions of the currents. It was clarified that Ampère's law applies correctly only when the B-field is constant along the loop, which is not the case here. The correct approach involves using the formula for the B-field from each wire and summing them, yielding a non-zero result. This highlights the importance of understanding the conditions under which Ampère's law can be applied accurately.
papercace
The problem is basically about tow infinite parallel wires separated by a distance ##d## with equally strong but opposite currents. You have to calculate the B-field outside the wires (not the field in between them).
Ampères law:
##\oint \mathbf B \cdot d\mathbf l = \mu_0 I_{enc}##
B-field outside one infinite wire with current I:
##B=\frac{\mu_0 I}{2\pi s}##
where ##s## is the distance from the wire.
Using the second formula on each wire and adding the resulting fields, we get the right answer, which obviously is bigger than zero. If we instead use Ampère's law, where we enclose both wires by an amperian circular loop, we get that the enclosed current is zero, since they run in opposite directions, which in turn makes the B-field equal to zero, which is obviously the wrong answer. In what way am I using Ampères law wrongly?
Ampères law:
Yes, it is wrong. What does Ampère's law exactly state?
It states that the sum of the strength of the B-field in a tangential direction to the loop is proportional to the current enclosed by the loop.
If I may guess, we can only solve the integral analytically if the B-field in the tangential direction is assumed to be a constant over the entire loop, which is not the case with two parallel wires. Am I on going on the right track?
Yes. The tangential component of the B field is not constant along a loop enclosing both wires.
Now I understand. It's useful to take an extra hard look at the formulas when trying to use them. Thanks :)
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
