A Corresponding case of steady precession but for Tait-Bryan angles
The discussion centers on the differences between Euler angles and Tait-Bryan angles in the context of rotational motion. While Euler angles can describe a special case of steady precession, Tait-Bryan angles do not exhibit a corresponding phenomenon due to their application in modeling planes and ships, which do not experience the same precessional behavior as gyroscopes. The consensus is that the choice of angles should be based on the specific problem being addressed, acknowledging that steady precession is relevant only in certain mechanical contexts. It is recognized that seeking parallels between the two systems may not be necessary or productive. Understanding these distinctions is crucial for accurate modeling in various fields.
Trying2Learn
TL;DR Summary
What is the corresponding case of steady precession but for Tait-Bryan angles
(This has continued to bother me. I tried asking, and no response. May I please try again?)
Using Euler angles, we rotate about an axis (often, axis three of a gyroscope frame), then a second (axis one of the gimbal frame), then return to the same axis as the first one (back to axis 3, but of the rotor frame) (all in the moving body frame): Precession, then Nutation, then Spin.
Using Tait Bryan angles, we go through a simliar process but this time, all three axes are different: Yaw, pitch, roll?
For Euler angles, there emerges a special case of Steady Precession:
  1. Precession RATE constant
  2. Nutation constant
  3. Spin RATE constant
What is the corresponding phenomena for the Tait-Bryan angles?
Or is that a non-sensical question? And why?
Sometimes, I think the case of steady precession is only for mechanical devices, and can best be described using Euler angles (precession, nutation, spin); and that there is NO SUCH corresponding phenomena when modeling a ship or plane using Tait Bryan (pitch, yaw, roll).
I think I am being a bit OCD trying to draw a parallel. I think I should accept the fact that one just choose the most suitable angles for the problem at hand, and just note that there is a special case of steady precssion for Euler angles (gyroscopes) and not for Tait-Bryan (planes and ships)
Thus, is it ridiculous to even ask about a special case when using Tait Angles (as we do with Euler angles)?
Your understanding is correct, there is no corresponding phenomena for Tait-Bryan angles. This is because Tait-Bryan angles are commonly used to describe the orientation of planes and ships, which do not exhibit the same type of precession as a gyroscope. The concept of steady precession only applies to rotational motion, and planes and ships do not typically experience this type of motion. Therefore, it is not necessary to try and draw a parallel between the two coordinate systems. As you mentioned, the choice of which angles to use depends on the problem at hand, and in this case, Tait-Bryan angles are more suitable for describing the orientation of planes and ships. It is not ridiculous to ask the question, but it is important to understand the limitations and differences between the two coordinate systems.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
