Cos, Tan, and Csc Problem: Evaluating Trigonometric Functions for a Given Theta
  • Thread starter Thread starter 01
    Cos Tan
To evaluate csc(theta) given cos(theta) = 1/2 and tan(theta) is negative, the discussion highlights that theta must be in the fourth quadrant. The angles corresponding to cos(theta) = 1/2 are pi/3 and 5pi/3, but since tan(theta) is negative, theta is determined to be 5pi/3. Consequently, csc(theta) is calculated as -2√3/3. The thread also briefly touches on a separate question about the phase shift of a sine function, which the user resolves independently.
01
doing a problem but can't figure out the answer:
Given the following, evaluate csc(theta):
cos(theta) = 1/2
tan(theta) = negative
a> 2
b> -2(square root of)3/3
c> 2(square root of)3/3
d> -2
any help?
cos(theta) = 1/2
a> 2
d> -2
any help?
i do not understand the part with the a b c and d in it but i can tel lyou that if you look at your unit circle (CAST) rule then you can fiure out the point where the cos is positive and the tan is negative
if cos theta = 0.5 and tan theta < 0 then theta can onlky lie in the first or fourth quadrant i.e. between 0 and 90 and 270 and 360
or if you care in radians 0 to pi/2 and 3pi/2 and 2pi
if the cos(theta) = 1/2, then (theta) = pi/3, or 5pi/3, on the interval [0, 2pi],
since it is given that tan(theta) = sin(theta)/cos(theta) < 0,
sin(theta)/(1/2) = 2sin(theta) < 0 or sin(theta) < 0,
therefore (theta) has to be (5pi/3)
now, csc(theta) = 1/sin(theta) = 1/(-3/(2sqrt[3]) = -2sqrt[3]/3
thx for the input, now here's another:
what is the phase shift for 3sin (3x+(pi/2))
a> -pi/6
b> 3
c> pi/2
d> -3pi/2
*the a,b,c,& d are multiple choices on the assignment I'm doing.
nevermind, i got it.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
