Could a black hole just be a planet?
In summary, there is currently no evidence that suggests that planets can exist inside of black holes, and the idea is more likely to be a theory in development rather than anything that we currently know to be true.
JLemp
TL;DR Summary
Just a thought that came to me after hearing any object or material, if compressed enough, could become a singularity.
So the theory is the center of a "black hole" is nothing more than a planetoid of incredibly dense material, and the black hole is just this planet's atmosphere for lack of a better description. Thoughts?
  • Skeptical
Likes BillTre, weirdoguy and PeroK
Astronomy news on Phys.org
No. There's nothing wrong with the concept of planetary mass black holes (one with the mass of the Earth would be about 1.5cm across). However, the point about a black hole is that there is no mechanism that can stop collapse once you overcome neutron degeneracy pressure, so you can't have a solid lump of matter in a black hole - it collapses because nothing is strong enough to stop it. Furthermore, the interior of a black hole is a complicated place - it doesn't have a center per se. The singularity (despite popular description) is not a point, but rather like a moment in time.
Note that all of the above is predicated on general relativity. At some point between here and the singularity we expect quantum gravitational effects to become apparent. Since we don't have a working theory of quantum gravity we can't say what those effects would be. Allowing planets in the core of black holes seems unlikely, though.
Likes JLemp and BillTre
JLemp said:
Summary: Just a thought that came to me after hearing any object or material, if compressed enough, could become a singularity.
A singularity is not a physical thing. It's a deficiency in the mathematical model.
Likes cosmologyscience, BillTre, FactChecker and 2 others
Sorry to be harsh, but it makes absolutely no sense in regards to being a plausible possibility with our current understanding of science.
Likes BillTre and malawi_glenn
No
Likes Bystander
People did propose something along those lines, albeit in more rigorous terms - the Planck stars:
https://arxiv.org/abs/1401.6562
At this point firmly in the hypothesis bucket, though.
(this is more like an evolving stage in a star's life, rather than a permanent planet-like object)
Likes malawi_glenn and Ibix
Note to OP; "neutron degeneracy pressure" is what keeps a neutron star/pulsar from collapsing if it's not quite massive enough to collapse into a black hole. That would be the "last"/densest known object that isn't a black hole.
Likes JLemp, pinball1970, malawi_glenn and 1 other person
Related to Could a black hole just be a planet?
1. Could a black hole actually be a planet?
No, a black hole and a planet are two very different types of celestial objects. A planet is a solid, spherical body that orbits a star, while a black hole is a region of space where the gravitational pull is so strong that nothing, not even light, can escape.
2. How can a black hole have the same mass as a planet?
The mass of a black hole is concentrated in a very small area, while the mass of a planet is spread out over a larger volume. This means that the gravitational pull of a black hole is much stronger, despite having the same mass as a planet.
3. Can a planet turn into a black hole?
No, a planet does not have enough mass to collapse into a black hole. In order for a celestial object to become a black hole, it must have a mass at least three times that of our sun.
4. Is it possible for a black hole to have a solid surface like a planet?
No, a black hole does not have a solid surface. As an object gets closer to a black hole, it experiences extreme gravitational forces that cause it to stretch and eventually be torn apart. This means that a black hole does not have a solid surface like a planet.
5. Can a planet orbit a black hole?
Yes, a planet can orbit a black hole just like it would orbit a star. However, the orbit would need to be at a safe distance to avoid being pulled into the black hole's gravitational pull.
  • Astronomy and Astrophysics
