Could you check if these two are equivalent?
  • Thread starter Chsoviz0716
  • Tags
    Equivalent
In summary, the ratio test states that the series Ʃa(n) will diverge if the absolute value of the ratio between the (n+1)th term and the nth term is greater than or equal to 1 for n≥N, where N is a fixed integer. The question is whether this condition can be replaced with the limit inferior of the absolute value of the ratio being greater than or equal to 1. The answer is yes, as long as the greater than or equal to symbol is replaced with just a greater than symbol in both cases.
Chsoviz0716
Hi guys,
This is from so called ratio test, which says
The series Ʃa(n) diverges if abs{a(n+1)/a(n)} ≥ 1 for n≥N where N is some fixed integer.
I was wondering if I could replace the condition with lim inf abs{a(n+1)/a(n)} ≥ 1.
So basically what I'm asking is whether these two below are equivalent or not.
1. abs{a(n+1)/a(n)} ≥ 1 for n≥N where N is some fixed integer
2. lim inf abs{a(n+1)/a(n)} ≥ 1
*a(n) means nth term in the sequence, and abs means absolute value.
Thank you in advance.
Chsoviz0716 said:
Hi guys,
No, it doesn't say that. You need to replace "[itex]\ge[/itex]" with ">".
Yes, if you replace that [itex]\ge[/itex] with ">" in each.
If it equals one, the ratio test is inconclusive.
FAQ: Could you check if these two are equivalent?
What does it mean for two things to be considered equivalent?
Two things are considered equivalent when they have the same value or meaning. This means that they can be substituted for each other in a given context without changing the overall outcome or result.
How do you determine if two things are equivalent?
To determine if two things are equivalent, you can compare their properties, characteristics, or behaviors. This can be done through observation, experimentation, or analysis using mathematical or logical methods.
Can two things be equivalent in one context but not in another?
Yes, two things can be equivalent in one context but not in another. This is because the concept of equivalence is relative and depends on the specific context or criteria being used for comparison.
What is the importance of checking if two things are equivalent?
Checking if two things are equivalent is important in various fields such as mathematics, science, and computer programming. It helps to ensure accuracy and consistency in calculations, experiments, and algorithms.
What are some common methods used to check for equivalence?
Some common methods used to check for equivalence include testing for equality, comparing values or outcomes, using logical operators, and performing statistical analyses. Other methods may also be used depending on the specific context or scenario.
