I Coulomb gauge Lorenz invariant?
Sebas4
TL;DR Summary
What is meant by Coulomb gauge not being Lorenz invariant?
Hey,
The Coulomb gauge is just a constraint on \mathbf{A} and \phi and thus it is independent of inertial frame.
I posted the question in the wrong section. This question is in the context of QFT. The notes says:
A disadvantage of working in Coulomb gauge is that it breaks Lorentz invariance.
Sebas4 said:
TL;DR Summary: What is meant by Coulomb gauge not being Lorenz invariant?
It means that if you have some four-potential ##A^\mu=(\phi,\vec A)## where ##A^\mu## satisfies the Coulomb gauge condition in some unprimed inertial frame, then ##A^{\mu'}=\Lambda^{\mu'}_\mu A^\mu## generally will not satisfy the Coulomb gauge condition in the primed inertial frame. It will still be a perfectly valid four-potential in the primed frame, but just not in the Coulomb gauge.
Of course you can write the Coulomb gauge in a manifestly covariant way.
The point is that usually you take an arbitrary inertial frame ##\Sigma^{*}## and write the Coulomb-gauge condition in (1+3)-notation as
$$\vec{\nabla}^* \cdot \vec{A}^*=0.$$
You can make this manifestly covariant by introducing the four-vector with components ##U^*=(1,0,0,0)## in this frame.
Then the Coulomb-gauge condition in a general frame reads
$$\partial_{\mu} (A^{\mu}-U^{\mu} U^{\nu} A_{\nu})=0.$$
The point is that you now have introduced a preferred inertial reference frame to define your gauge constraint.
Using this covariant notation, you get a manifestly covariant photon propagator, containing the ##U^{\mu}## of course. Now the important point is that due to gauge-invariance for any physically observable quantities like S-matrix elements for scatterings between photons and electrons+positrons in standard spinor QED the frame-dependent terms, i.e., those containing ##U^{\mu}## cancel thanks to the Ward identities.
The advantage of the Coulomb gauge is that you have a complete gauge fixing and no unphysical degrees of freedom. The disadvantage is this "fictitious breaking of Lorentz symmetry" due to the introduction of an arbitrary reference frame, i.e., the vector ##U^{\mu}##.
You can also use a manifestly covariant gauge like the Landau gauge, demanding ##\partial_{\mu} A^{\mu}=0##, but this fixes the gauge only partially, and you have to deal with unphysical degrees of freedom like longitudinal and timelike photons, which however also cancel using the Gupta-Bleuler formalism. The advantage is that there's no arbitrary preferred frame and the Feynman rules lead to simpler expressions.
Likes dextercioby and Dale
I asked a question here, probably over 15 years ago on entanglement and I appreciated the thoughtful answers I received back then. The intervening years haven't made me any more knowledgeable in physics, so forgive my naïveté ! If a have a piece of paper in an area of high gravity, lets say near a black hole, and I draw a triangle on this paper and 'measure' the angles of the triangle, will they add to 180 degrees? How about if I'm looking at this paper outside of the (reasonable)...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
