MHB Coulomb's Constant in electron energy formula.
The discussion centers on the inclusion of Coulomb's constant, represented as \( \frac{1}{(4\pi\epsilon_0)^2} \), in the electron energy formula for the nth Bohr orbit. The formula \( E_n = -\frac{2\pi^2me^4Z^2}{n^2h^2} \) is derived by equating centripetal and electric forces, while incorporating quantum mechanical principles. The presence of \( (4\pi\epsilon_0)^2 \) arises from the mathematical manipulation of the equations governing electric and kinetic energy in the context of the Bohr model. This constant is essential for accurately reflecting the electrostatic interactions in atomic systems. Ultimately, the discussion emphasizes the importance of Coulomb's constant in deriving the energy levels of electrons in hydrogen-like atoms.
WMDhamnekar
MHB
Hi,
If we multiply $En=-\frac{2\pi^2me^4Z^2}{ n^2h^2} $by $\frac{1}{(4\pi\epsilon_0)^2},$ it is the formula of electron energy in nth Bohr’s orbit. Why we should multiply it by $\frac{1}{ (4\pi\epsilon_0)^2}$ a Coulomb's constant in electrostatic force?
Where m=mass of electron, e= charge on electron h=Plank's constant, n=principal quantum number, Z= atomic mass number of element (Bohr'theory can only be applied to ions containing only one electron.$e.g. He^+, Li^{2+}, Be^{3+} $etc.
Mathematics news on Phys.org
Bohr's model is a classical mechanical model that treats the electron as a point particle that orbits the nucleus. Additionally it has the quantum rule that the angular momentum $L$ must be an integer multiple of $\hbar$.
Consequently we have:
\[ \begin{cases} F_{centripetal} = F_{electric} \\ E_{total} = E_{electric} + E_{kinetic} \\ L = n\hbar \end{cases} \implies
\begin{cases} \frac{m v^2}{r} = \frac{Ze\cdot e}{4\pi\epsilon_0 r^2} \\ E_n = -\frac{Ze\cdot e}{4\pi\epsilon_0 r} + \frac 12 m v^2 \\ m v r = n\hbar \end{cases} \]
Now eliminate $v$ and $r$ from those equations.
The result is:
$$E_n = -\frac 12 \frac{Z^2e^4 m}{(4\pi \epsilon_0)^2 n^2 \hbar^2}
=-\frac{2\pi^2Z^2e^4 m}{(4\pi \epsilon_0)^2 n^2 h^2}$$
Why do we see $(4\pi\epsilon_0)^2$ in this formula?
As I see it, it's the consequence of combining the given formulas that happen to contain some squares.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
