Counting d-electrons in M(I) transition metals
  • Thread starter Thread starter Mayhem
The discussion centers on the calculation of d-electron counts for first-row transition metals, specifically addressing the nuances of electron configuration and oxidation states. It highlights that the d-electron count is derived by subtracting the metal's group number from its oxidation state, with a focus on Co(I) and its electron configuration of [Ar]3d74s1. The conversation explores whether the 4s electron should be considered a d-electron or if it is "demoted" to a d-orbital upon oxidation. Participants acknowledge the complexity of electron behavior, noting that the energies of orbitals are closely related, making definitive assignments challenging. The discussion also touches on the implications for spectroscopy, suggesting that Co(I) complexes may exhibit different electronic transitions compared to other d8 complexes due to ligand field effects that distort orbitals and alter their energies. Overall, while simplified models of electron configuration are useful, they may not fully capture the complexities of electron behavior in transition metals.
Mayhem
Formally, d-electron count is calculated by subtracting the group number of the metal by its oxidation state.
If we limit ourselves to the first row transition metals, the group number - 2 = #d-electrons
Co(I) (group 9) only loses one electron. Its electron configuration becomes [Ar]3d74s1.
Thus our d-electron "count" involves an electron in the s-orbital. This cannot be insignificant. In practice, is the 4s electron counted as a d-electron formally or is it "demoted" into a d-orbital when it is unpaired via oxidation?
Chemistry news on Phys.org
Sorry for being late, I hoped someone will have better answer than my somewhat handwavy treatment.
My understanding (which can be wrong, QM was never my forte) is that energies of these orbitals are so close there is no way to say where the electron "resides" and detailed discussion is a moot.
In a way assigning electrons to orbitals is just a simplification stemming from the single electron model. Schroedinger equation gives a single wavefunction describing all electrons at once, and it doesn't put them in separate boxes. Yes, thinking in terms of electron configuration is a valuable tool, but as every simplified model it sometimes fails.
Thank you Borek.
Indeed, the reality of electrons is much stranger than how we model it in chemistry.
But does this have any implications for spectroscopy, i.e. would Co(I) complexes have different allowed electronic transitions than other d8 equivalent complexes.
In complexes it is much better to speak about MO, not AO.
Generally speaking, if you were trying to predict spectra that could be the case, but my bet is that this is a bit different situation - in complexes ligand field "distorts the orbitals"* and changes their relative energies, so electron assignment to these "orbitals" is much easier and much better defined, that's why these complexes exist.
*Quotes to avoid being inconsistent and write "orbitals exist" and "orbitals don't exist" in neighboring posts :wink:
Somewhat oversimplified, I think you can assume that all valence electrons in d-block elements are d-electrons if the atom has a positive oxidation number. The reason is that with increasing atomic charge, the atom gets more hydrogen like and the aufbau principle will be followed (i.e. d will be filled before s of the next shell. A semiquantitative understanding is possible applying the so-called "Slater-rules".
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
