MHB Couple of hard trig questions....
  • Thread starter Thread starter Sabrina102
    Couple Hard Trig
The discussion revolves around solving several trigonometry-related problems. The first question involves determining the vertical shift, c, in a sinusoidal equation based on given inflation rates. The second question asks for the duration it takes for the moon to return to a full moon and the corresponding period, k. The third question explains why circles of different radii have the same number of radians, while the fourth discusses how multiplying by values greater or less than one affects the period of trigonometric functions. The final question requires identifying intervals of positive, negative, and zero average rates of change for a specific sinusoidal function.
Sabrina102
Hi, I was hoping to get some help on these five questions, I've been stuck on these and any help would be greatly appreciated!
1. Inflation rises and falls in a cyclical manner. If inflation is highest at 4.8% and lowest at 1.3%, what c for the equation y = a sin(k(x + d)) + c?
2. If the moon changes from a full moon to a half moon in 13 days, how many more days does it take for it to get back to a full moon and what would the period, k, equal?
3. Explain why a circle of radius 4 cm and a circle of radius 13 m have the same number of radians?
4. Explain why when you multiply by a number greater than 1 inside the argument of a trigonometric function, the period of the function decreases and when you multiply by a number less than 1, the period increases.
5. For the function y = 4sin (pi/ 4 x - pi/2 ) - 3 list when the average rate of change is positive, negative, and zero, considering the beginning of the interval to be x = 4.
Mathematics news on Phys.org
Hello, and welcome to MHB! (Wave)
1.) I would begin by stating:
$$-1\le\sin(k(x+d))\le1$$
$$-|a|\le |a|\sin(k(x+d))\le |a|$$
$$-|a|+c\le |a|\sin(k(x+d))+c\le |a|+c$$
And so, from the information given in the problem regarding the minimum and maximum values of inflation the sinusoid is modelling, we must have:
$$c+|a|=4.8\%$$
$$c-|a|=1.3\%$$
Add these equations, and then solve for \(c\)...what do you find?
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
