Coupling to the shaft of an electric motor (different size shafts)
  • Thread starter Thread starter bu4ck
For coupling to an electric motor with different shaft sizes, using short splined shafts from PTO suppliers is recommended. Taper Lock bushes can accommodate various shaft diameters, and selecting a system larger than the shafts to be joined is essential. Taper lock flexible couplings, including HRC types, are also available for this purpose. Additional information, such as dimensions and photos of the motor setup, is necessary for more tailored advice. Proper coupling solutions can enhance the performance and compatibility of electric motors with varying shaft sizes.
bu4ck
[Mentor Note -- thread spun off of a different thread]
Baluncore said:
You may find it easier to avoid the gear. Short splined shafts are stock items and can be purchased from PTO shaft and drive-line suppliers.
"Taper Lock" bushes are available for any diameter shaft. Google "Taper Lock".
There are several taper lock systems in different sizes available. Select a system that is bigger than either shaft to be joined. Then get two different bushes to fit the shafts.
There are also taper lock flexible couplings of different types.
Look at the taper lock HRC Couplings.
https://pineriversbearings.com.au/power-transmission/couplings/
And there are bigger, more tolerant systems.
https://www.ebay.com.au/itm/332854007597
Hi. Could you help me with some advise on an electric shaft driven motor, the casing/shaft rods are too wide, can I get shorter ones to fit a 60v brushless motor? I’m a complete novice
Hi and welcome to PF. We need a lot more information about this before making any recommendations. A photo might help, showing the motor and were it's supposed to go. Some actual dimensions are needed.
Likes russ_watters
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
