I Courant and Fritz, Construction of the real numbers
GodfreyHW
In chapter 1, page 10, real numbers are found by confining them to an interval that shrinks to "zero" length (we consider subintervals ##I_0,\,I_1,...,\,I_n##). Basically, if ##x## is between ##c## and ##c+1##, then we can divide that interval into ten subintervals, and we can, then, have ##c+\frac{1}{10}c_1\leq x\leq c+\frac{1}{10}c_1+\frac{1}{10}##, where ##c_1## is a digit from zero to nine.
Repeating this process, and making ##n\to\infty## subdivisions, we'll eventually get ##x=c+0.c_1c_2c_3...##
I am confused by this, though:
1) How is he constructing that ##I_{n+1}## interval?
If I suppose ##c_0-1\leq x##, then I can do ##c_0-1+\frac{1}{10}c_1+...+\frac{1}{10^n}c_n\leq x##, and if I say that ##n\to\infty##, then I can also write ##\underbrace{(c_0-1+\frac{1}{10}c_1+...+\frac{1}{10^n}c_n)}_x-\frac{1}{10^{n+1}}\leq x##, so that ##\frac{1}{10^{n+1}})## is like an infinitesimal.
Would this be correct for ##\left[x-\frac{1}{10^{n+1}},x\right]##? If so, then I guess that it should be the same with ##x\leq c_0+1## by subtracting ##\frac{c_i}{10^i}##s and adding ##\frac{1}{10^{n+1}}##.
2) How is he getting the second representation with ##c_n-1##? (typo?)
I see that, maybe, we'd do ##c_0\leq x##, and get it to ##c_0+\frac{1}{10}c_1+...+\frac{1}{10^n}c_n\leq x##, but we would have ##c_{i>0}=9##.
As for 2)
For an example
0.123450000...
c_5=5
c_5-1=4
so it is equal to
0.123449999...
Likes GodfreyHW
anuttarasammyak said:
As for 2)
For an example
0.123450000...
c_5=5
c_5-1=4
so it is equal to
0.123449999...
Yes, thank you!
I posted this question on math-stackexchange but apparently I asked something stupid and I was downvoted. I still don't have an answer to my question so I hope someone in here can help me or at least explain me why I am asking something stupid. I started studying Complex Analysis and came upon the following theorem which is a direct consequence of the Cauchy-Goursat theorem: Let ##f:D\to\mathbb{C}## be an anlytic function over a simply connected region ##D##. If ##a## and ##z## are part of...
