Covariant derivative and the Stress-enegery tensor
The discussion centers on the covariant derivative of the stress-energy tensor, specifically examining the expression involving the scalar field φ and the constant C. The calculations show that under the Levi-Civita connection, the covariant derivative simplifies, leading to the conclusion that C must equal 1 for consistency with established results in field theory and general relativity. A typo was identified in the calculations, but the overall manipulations were confirmed as valid. The final agreement on C = 1 aligns with standard references in the field, reinforcing the correctness of the approach.
Markus Kahn
Let ##\phi## be a scalar field that obeys the wave equation, i.e. ##\nabla_a\nabla^a\phi = 0##. How do you need to chose the constant ##C## for the Stress energy tensor
$$T_{a b}=\nabla_{a} \phi \nabla_{b} \phi-\frac{C}{2} g_{a b} \nabla_{c} \phi \nabla^{c} \phi$$
to be conserved, i.e. satisfy ##\nabla_a T^{ab}=0##?
All given in the question.
My try:
\begin{align*}
\nabla^a T_{ab}
&= \nabla^a \left(\nabla_{a} \phi \nabla_{b} \phi-\frac{C}{2} g_{a b} \nabla_{c} \phi \nabla^{c} \phi\right)\\
&\overset{(1)}{=} \underbrace{(\nabla^a\nabla_{a} \phi)}_{=0} \nabla_{b} \phi + \nabla_{a} \phi (\nabla^a\nabla_{b} \phi)-\frac{C}{2} \underbrace{(\nabla^ag_{a b})}_{=0} \nabla_{c} \phi \nabla^{c} \phi~ \underbrace{ - \frac{C}{2} g_{a b} (\nabla^a\nabla_{c} \phi) \nabla^{c} \phi -\frac{C}{2} g_{a b} \nabla_{c} \phi (\nabla^a \nabla^{c} \phi)}_{= Cg_{ab}(\nabla^a\nabla_{c} \phi) \nabla^{c} \phi }\\
&= \nabla_{a} \phi (\nabla^a\nabla_{b} \phi) - Cg_{ab}(\nabla^a\nabla_{c} \phi) \nabla^{c} \phi\\
&\overset{(2)}{=} \nabla_{a} \phi (\nabla^a\nabla_{b} \phi) - C\nabla_{a} \phi(\nabla_b\nabla^a \phi)\\
&= \nabla_{a} \phi [\nabla^a\nabla_{b} \phi - C\nabla_b\nabla^a \phi],
\end{align*}
where in ##(1)## I assumed we are working with the Levi-Civita connection (i.e. ##\nabla_a g_{bc}=0##) and the fact that ##\phi## satisfies the wave equation. In ##(2)## I just relabeled the indices and contracted the metric with the connection.
This is where I'm stuck. I'm not really sure how to proceed from here. I thought that one could maybe make use of the fact that the covariant derivative acts especially nicely on scalar fields, i.e.
$$\nabla _a \phi = \partial_a \phi\quad \Longrightarrow \quad\nabla_b \nabla_a \phi = \partial_b\partial_a\phi - \Gamma^{k}_{ab}\partial_k \phi,$$
we modify the statement slightly to our case, i.e.
$$\nabla_a\nabla^b\phi = \nabla_a (g^{bc}\nabla_c\phi) = g^{cb} \nabla_a\nabla_c\phi = g^{cb}(\partial_c\partial_a\phi - \Gamma^{k}_{ac}\partial_k \phi).$$
This then results in
\begin{align*}
\nabla^a T_{ab}
&= \nabla_{a} \phi [\nabla^a\nabla_{b} \phi - C\nabla_b\nabla^a \phi]\\
&=\nabla_{a} \phi [g^{ab}(\partial_b\partial_c\phi - \Gamma^{k}_{cb}\partial_k \phi)- C g^{ab}(\partial_c\partial_b\phi - \Gamma^{k}_{bc}\partial_k \phi) ]\\
&\overset{C=1}{=} \nabla_a \phi g^{ab}[ \underbrace{[\partial_b,\partial_c]}_{=0}\phi + \underbrace{(\Gamma^k_{bc}-\Gamma^k_{cb})}_{=0}\phi ]\\
&=0,
\end{align*}
where the Christoffel-symbols cancel since we chose the Levi-Civita connection, i.e. a torsion-free connection.
So the result would be ##C=1##... I'm really skeptical about this, so I would appreciate if someone could take a look at it and confirm that I'm not doing nonsense or give me a hint where I went wrong.
Your work looks good to me except for a typo in the second line below. The ##g^{ab}## factors in this line should be ##g^{ac}##. But, you can see that your result still follows.
Markus Kahn said:
\begin{align*}
\nabla^a T_{ab}
\end{align*}
Why are you skeptical that ##C = 1##?
Likes Markus Kahn
Thanks for spotting the typo. I'm rather new to this entire GR-formalism, i.e. the covariant derivatives, etc., so I was just a bit unsure if I'm really doing operations that are permitted. Also, ##C=1## seemed a bit odd in the first moment, but if you think this works, then I'm happy!
Looks like you are quite proficient with the manipulations.
C = 1 makes the overall coefficient equal to 1/2 in the last term of the expression for the stress energy tensor. This agrees with what you will find in various field theory and GR texts. For example, equation (9.1.16) here or equation (3.27) here with ##m## set to zero.
Likes Markus Kahn
Perfect, thanks a lot for checking and looking up the references!
  • · Replies 36 ·
  • · Replies 42 ·
9K
