COVID-19: How to Stay Safe & Healthy
  • Thread starter Thread starter ellieee
    Covid-19
ellieee
why will angle of incidence on the surface of the lens be greater when point light source is nearer to the lens?
nil
nil
ellieee said:
Homework Statement:: why will angle of incidence on the surface of the lens be greater when point light source is nearer to the lens?
Relevant Equations:: nil
nil
Have you tried drawing a diagram?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
