Create a physics problem for me!
A user requested a physics problem involving kinematics, dynamics, and calculus. The response highlighted that creating original problems isn't the forum's focus and suggested using resources like Irodov's problems or the math challenges available online. A specific classical mechanics problem was provided, which involves proving that an object falling from deep space takes 9/11 of the fall time to reach half the distance to Earth. The solution requires relating distance to time using Newton's law of gravitation. The thread concluded with the indication that it would remain closed as the inquiry had been adequately addressed.
silento
Hello! Using concepts of physics 1 like kinamatics, dynamics, circular motion, pressure, newton's laws. Make me a physics question that needs basic calculus like integrals and derivaties to solve!
We are not in the business of making up problems. Do you know how to use the Internet?
Likes MatinSAR and BvU
Irodov has lots of good problems!
Likes MatinSAR, PhDeezNutz and silento
There’s a classical mechanics problem that is simple to state but can be hard depending on how you go about it. It has elements of Newton's gravitation, orbits, dynamics and kinamatics.
Prove that an object originating in deep space falling toward the earth will take 9/11 of the time of fall to travel half the distance.
It’s from the book Classical Dynamics by Marion in Chapter 5 problem 5-5 on page 205.
Basically you have to relate the distance to time but newtons gravitation law gives the acceleration based on distance.
One could do this problem numerically with python or some other programming language which would introduce you to computer modeling in a small domain.
One prof told us to use the Kepler equal areas in equal times law and consider the object is orbiting the earth in an elliptical orbit and just collapse the orbit ie minor axis goes to zero.
Since the thread has been answered as best as can be, it will remain closed.
Jedi
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
