Creating an AC Circuit with 2 Light Bulbs & a Switch
  • Thread starter Thread starter abro
    Circuit
To create an AC circuit with two light bulbs and a switch, a DPDT (Double Pole Double Throw) switch is recommended. One bulb will light when the switch is open, while the other will light when the switch is closed, achieving the desired effect. The discussion emphasizes that using a DPDT switch is straightforward and requires minimal components. Participants express relief that the setup is simpler than initially anticipated. Overall, the circuit design is confirmed to be easy to implement.
abro
Hi I want to make a circuit with AC and 2 light bulbs and a switch. One light bulb will light when the switch is open, but will be off when the switch is closed. The other bulb will have the opposite effect.
I tried to use transistors but that only works for DC current.
You want a simple DPDT (Double Pole Double Throw) switch. What you are describing is a common use of a DPDT switch and you can buy them at any hardware store.
Thanks, thought a bit too difficult.
Sorry, I don't know what you mean. Do you mean that you though it would be difficult and are happy to find out that it is easy or do you mean that you think a DPDT switch is too difficult? There aren't very many things more simple than a DPDT switch and for what you want to do there is NOTHING that is more simple.
What I mean is that I thought it would require a lot of parts, but turns out it's that simple.
Yes, good. It IS simple.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
