Current and magnetic field in a spherical capacitor
In summary, Irene said that there is current from one sphere to the other, but there is no flux. B = 0.
fabiogn
<< Mentor Note -- Thread moved from the technical forums,. so no HH Template is shown >>
Hello! I have a question on Electromagnetics.
Could anyone check if I am on the right track?
Here is the proposed problem:
Consider a spherically symmetric current distribution, which is radial and corresponds to the slow leak between the plates of a spherical capacitor. Considering now the magnetic flux B caused by this current, choose the right one:
Among the five alternatives there is one that affirms that the magnetic flux is zero outside and inside this capacitor because magnetic field lines never cross and always form closed paths.
Since I cannot figure out how the magnetic poles and field lines regarding the condition above described would be, (it would be like a monopole) I think that this alternative is the right one.
I also have found the text below, which reinforces my point of view:
"because since we have a completely spherically symmetric situation, it could only generate a spherically symmetric magnetic field. But the only possible such fields are one pointing outwards everywhere and one pointing inwards everywhere, both corresponding to non-existent monopoles. So, there can be no magnetic field" Has anyone seen this problem before? Am I right?
Many thanks in advance,
Best regards!
Fabio
We can also regard a miniscule current along the radius from one plate to the other. According to the Biot-Savart law, it creates the magnetic flux Bi. Then, we can easily find the opposite current to create -Bi. And, owing to the spherical symmetry, each elementary magnetic flux has its opposite flux. In the end, their total vector sum is 0.
Hi Irene, many thanks for your reply!
Let me see if I got it right... So, does it mean that internally there is magnetic flux between the two spherical surfaces of the capacitor?
I really appreciate your help.
There is current from one sphere to the other, but there is no flux. B = 0
Dear Irene,
Ok! I understood! Many thanks for your help!
Fabio
Related to Current and magnetic field in a spherical capacitor
1. What is a spherical capacitor?
A spherical capacitor is a type of capacitor that consists of two concentric spherical conducting shells separated by a dielectric material. It is used to store electric charge and create a uniform electric field between the two shells.
2. How does a spherical capacitor create a magnetic field?
When a voltage is applied to a spherical capacitor, an electric field is created between the two shells. This electric field creates a displacement current, which in turn generates a magnetic field around the capacitor.
3. What is the relationship between the current and magnetic field in a spherical capacitor?
The current in a spherical capacitor is directly proportional to the magnetic field. This means that as the current increases, the magnetic field also increases.
4. How is the magnetic field strength calculated in a spherical capacitor?
The magnetic field strength in a spherical capacitor can be calculated using the formula B = μ0 * I / (4 * π * r), where μ0 is the permeability of free space, I is the current, and r is the distance from the center of the capacitor.
5. Can the magnetic field in a spherical capacitor be controlled?
Yes, the magnetic field in a spherical capacitor can be controlled by adjusting the current or the distance between the two shells. By increasing or decreasing these factors, the strength of the magnetic field can be altered.
