B Current-carrying coil and solenoid
The primary distinction between a current-carrying coil and a solenoid lies in their shapes. A solenoid is specifically a helical coil, while other forms of coils, such as toroidal or planar spirals, do not qualify as solenoids. Both structures consist of multiple turns of wire carrying the same current, but their geometric configurations define their classifications. The discussion emphasizes that the shape is the key factor in differentiating between the two. Understanding these differences is crucial for applications in electromagnetism and circuit design.
Meow12
What is the difference between a current-carrying coil and a solenoid?
Baluncore said:
The difference is the current.
https://en.wikipedia.org/wiki/Solenoid
Assume that the same current I passes through the coil and the solenoid. Honestly, that picture in the Wikipedia article looks like a coil to me. It seems that both a coil and a solenoid have N turns of a current-carrying wire with radius r, and I don't see the difference.
Then the only difference is the shape of the coil.
A solenoid is a helix.
A coil wound on a toroid, or as a planar spiral, is not a helix, so not a solenoid.
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
