Current of Phasor going in CCW direction
The discussion centers on determining the correct representation of a current phasor rotating counterclockwise (CCW) in the equation vo(t). A participant questions whether the current should be expressed as -5cos(10t - 45) instead of 5cos(10t - 45) due to its CCW direction. It is clarified that inverting the amplitude corresponds to a 180-degree phase shift, but to change the rotation direction, a negative sign must be applied differently in the equation. The conversation emphasizes understanding how each term in the equation influences the function's behavior. Ultimately, the correct approach to represent the phasor's direction is crucial for accurate analysis.
smstepanic
Hi,
I feel I have solved this problem correctly (solving for vo(t)), however since the current is going in the ccw direction, would this make the current -5cos(10t - 45) versus 5 cos(10t -45)? This may be a simple question, so I am just making sure. Thanks!
smstepanic said:
Hi,
Inverting the amplitude is the same as adding a 180-degree phase shift. To make the rotation direction different, you need a negative sign in a different place...
Likes smstepanic
I think I understand. A 180 degree phase shift would apply to the -45 degrees. So 5cos(10t + 135)?
Um, no, that's not what I meant.
Regardless of the problem you posted, if you want the phasor to rotate in the opposite direction, you need to multiply by -1 where in the equation? Think about how each term in the equation affects the function...
Likes smstepanic
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
