Engineering Current through inductor in a circuit with a sinusoidal voltage source
The discussion centers on calculating the current through an inductor in a circuit with a sinusoidal voltage source. The inductors can be simplified to a single 8 H inductor, leading to the equation iL = (6 / 8) * ∫ cos 100t dt = 0.0075 sin 100t. The confusion arises regarding the initial condition iL(t0) and the assumption that it can be set to zero at t0 = 0. It is clarified that at the moment the voltage is applied, the current through the inductor cannot change instantaneously, confirming that the current is indeed zero at t = 0. Understanding this concept resolves the initial query about the integration limits and initial conditions.
AbbeAbyss
http://www.wifstrand.se/Albert/stuff/p7.7-1.png
vL = L * (diL / dt).
All of the inductors can be reduced to a single 8 H inductor, so
if you integrate from 0 to t.
The formula states that iL = iL(t0) + ∫ vL dt if you integrate from some initial condition current t0 to t. I get the correct answer if I integrate from 0 to t, but I fail to see what iL(t0) is and how we can use 0 for the lower bound.
It seems as if we can just assume that t0 = 0 and that iL(t0) = 0, if so, why is that?
You have di/dt = V/L so
i = ∫(V/L)dt + constant (indefinite integral + a constant)
To evaluate the constant, asume V = 0 for t < 0. Then, at t = 0, a sudden voltage V = 6V is applied to L. What is the current then at t = 0? What is the constant? Do you see now why your last statement is correct?
Yes, I see now that at t = 0 (or rather t = 0+ denoting the exact moment the voltage 6 * cos 0 is applied) the current is 0 since the current through an inductor can't change instantaneously, thanks.
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
