- 10,410
- 1,588
Suppose we have a 2-sphere, and an associated metric. For specificity
$$d\theta^2 + \sin^2 \theta d\phi^2$$
On this 2-sphere, lets consider two different connections. The Levi-Civita connection, where geodesics are great circles, and a connection with torsion where the curves of constant ##\theta## are geodesics. I don't have a name for this, - for now I'll call it the compass connection.
Let's consider a simple example of a geodesic triangle for each of the two connections. In our example, two of the sides of the triangle will be lines of constant 'longitude' (i.e. curves of constant ##\phi##). The third side will be in the case of the Levi-Civita connection a great circle, and in the compass connection a curve of constant latitude (constant ##\theta##). Essentially, we are comparing triangles that share the exact same three vertices, but using different connections to draw the sides of the triangle.
The sums of the internal angles on these two different geodesic triangles with different connections on the same geometry will be different. Because geodesics parallel transport themselves, the sum of the internal angles relates to the Riemann tensor, so the Riemann tensor must be different for the two different connections.
The first question is if this argument is correct (I don't see how it can be wrong, but I'm not as good at spotting errors in my thinking nowadays as I once was). Related questions arise as how to go about thinking of this. Does the concept of a surface of uniform curvature require a metric to define? What about the idea of "similar triangles", does that also require a metric? When we talk about "geometry", does changing the connection within the same metric change the geometry? That's a bit of a semantic question, but I'm unclear about standard usage.
