Cut lemon moved by itself
In summary, "Cut lemon moved by itself" refers to an intriguing phenomenon where a sliced lemon appears to exhibit autonomous movement, often prompting curiosity and speculation about the underlying causes, such as natural reactions, environmental factors, or even the influence of external forces.
mii
Hi ,
In one of my friends place , she cut the lemon in half and left it . She saw the lemon rotated to other direction by itself .
She saw it twice on different days ,why does this movement occur ?
How could we possibly know? Maybe the cat moved it. Try posting a video of this happening and we can discuss it.
  • Haha
Likes Vanadium 50, pinball1970, docnet and 1 other person
Welcome to PF.
How was the lemon cut? Equator or pole to pole?
How was the lemon placed, cut face down, or on its side?
Did sunlight fall on the lemon?
Was it in a refrigerator?
Who has access to the lemon?
Could someone be gaslighting your friend?
mii said:
Hi ,
Looks like another "drive-by;" wet counter tops that aren't level do this all the time.
Likes russ_watters and mii
Or maybe some roaches. ?:)
Baluncore said:
Welcome to PF.
what happens if sunlight falls on lemon ?
Lemon was cut in half, cut face is up.
It was outside .no one has access .. no gas lighting stuff . Some physics related .. could be wet surface or a plate or since
Lemons generate a bit of electricity , something triggered the rotation .
When you place a cut lemon on a marble counter top, does the citric acid react with the CaCO3to produce a CO2 support cushion inside the lemon? When the lemon warms, the gas expands and the lemon goes mobile.
The "sailing stones" of the Racetrack Playa, Death Valley, employ ice to do a similar thing. Nothing happens for a couple of years, then overnight everything moves.
https://en.wikipedia.org/wiki/Sailing_stones
It was outside .
The lemon is free to rotate. The shape of a lemon prevents it from standing with the axis truly vertical, so it leans slightly, like a weather vane. Then the local diurnal wind variation, like a sea breeze in the afternoon, could reorient the lemon.
. very interesting info.. thank you
It is an extremely rare sight.
It happens when a lonely lemon feels bad about something.
It was cut in half. This hurts the lemon.
The lemon then thinks "when life gives you lemons, make lemonade", so it starts to rotate to look around for other lemons.
But then it gets confused and stops since there are no other lemons around.
Just joking, of course :smile:. Lemons don't have feelings...
...as far as I know, at least. But then again, who knows?
  • Haha
Likes Tom.G, Klystron and berkeman
I see that people missed the most important question. Does this work with limes as well, or only lemons?
Likes symbolipoint
I think we need to blow up a few balloons, then carry out a group experiment. Various forms of lubrication should be investigated, lemon tea, or tequila?
  • Haha
Likes DennisN
mii said:
Hi ,
One or more mice came in while she was away, checked the lemon, decided it was not suitable, and left.
I'm surprised the cat didn't get them.
It did, with a squeeze of lemon.
(1) Not sure if mice have any interest in lemons as food
(2) Not everyone has cats
This thread is a fever dream---a strange mix of technical analysis and comedy.
Likes DennisN, symbolipoint and BillTre
mii in wonderland.
  • Haha
Likes Haborix
At least a little fun!
Likes Haborix
FAQ: Cut lemon moved by itself
What does it mean when a cut lemon moves by itself?
The phenomenon of a cut lemon moving by itself is often attributed to the release of gases or chemical reactions occurring within the lemon. However, it can also be a result of external factors such as vibrations or environmental changes.
Is there any scientific explanation for a cut lemon moving?
Yes, scientific explanations may include the release of gases from the lemon's cells or the effects of external forces like air currents or vibrations. In some cases, the lemon may appear to move due to the uneven distribution of juice and the resultant changes in weight distribution.
Can a cut lemon actually have any kind of movement?
A cut lemon does not have the ability to move on its own as it is a non-living object. Any perceived movement is likely due to external influences rather than any inherent property of the lemon itself.
Could the movement of a cut lemon be an illusion?
Yes, the movement can sometimes be an optical illusion or a trick of perception. Factors like light reflection, shadow play, or the way the lemon is positioned can create the appearance of movement.
What should I do if I see a cut lemon moving?
If you observe a cut lemon moving, it is advisable to investigate the environment for possible explanations, such as air currents or vibrations. It is unlikely to be a supernatural event, and understanding the physical context can provide clarity.
16K
