Cutting 6mm Dia Glassfiber Disks - Tips & Ideas
  • Thread starter Thread starter beho86
    Machining
The discussion centers on cutting 6 mm diameter disks from a layered glassfiber composite, with participants sharing various cutting methods. Suggestions include using a wood plug cutter, which is affordable and effective when mounted on a drill press, and the potential for using a CNC mill for precision, though it may waste material. Participants also mention the option of hand-cutting oversized disks and sanding them to size, which could be time-consuming given the volume needed. The use of an abrasive water jet is noted as providing the best surface finish, but cost is a concern. Ultimately, the wood plug cutter was successfully tested and proved to be an efficient solution for the task.
beho86
Hello,
I am working on a project, and I need to cut ~ 6 mm dia disks, and 3~4 mm thickness. The material is a composite made out of layered glassfiber. I am cutting those samples out of a 5 x 5 in composite.
My question is what is the best, accurate, and affordable way to cut those samples?
I tried to use a punch through the panel, but it gave me a destroyed disk. I have a custom made hallow cutter to cut the disks, but the tip bended with only 2 ~3 samples prepared.
I was thinking about using a hole saw, but I couldn't find a 1/4 in dia cutter, as I need the disks to have well refined edges. Any tips or ideas?
Most plastics including reinforced materials are commonly machined just like metals on lathes, mills, etc... This is a lathe cut part.
so, probably the only way is to use a CNC mill, but it is going to waste a lot of materials. Thanks for the suggestion Q_Goest
You might try a wood plug cutter. These work in a drill press and are used to cut round plugs from a board. 1/4 in. is a common size. Fiberglass can usually be worked with wood cutting tools. Plug cutters are cheap, so give it a try.
Yeah, the wood plug sounds good, as long as your setup is very rigid. I'm assuming you won't have a center drill because you want an entire disc, so you'll have to find a way to mount the plug cutter.
Also don't underestimate making an oversize cut by hand and then sanding it to the desired radius. It will take a little finesse, but it is the cheapest way, and if it meets your tolerances/specs, there's no reason not too.
Lastly, a cnc mill will give you the best results, and you could potentially lose the least amount of material depending on what end-of mill you use.
What is the thickness of th 5*5 sheet you have and what are your tolerances?
Plug cutters mount in a standard drill press chuck, same as a drill. They do not have a center hole, although some have a centering pin, which I think retracts as you drill. Once you've run the plug cutter, you cut the plug free from the block with a saw (band saws work good for this, also hand saws). Cut the plug a little longer than needed and then sand to final length.
You can buy one at Home Depot or Loews, shouldn't need to go to a high end or specialty store.
I was thinking about using plug cutters, but It will probably waste the same amount if I were to mill the disk using 1/8 end mill. don't the disk gets stuck inside the plug cutter?
I will try to use the cnc mill tomorrow and see.
The thickness of the 5 x 5 in blocks is about 4 mm. refining the disk by hand will take a lot of time, as I will be cutting more than 50 disk. Thanks guys
For that material, abrasive water jet will give you the best surface finish.
Is this FR4 or a similar material? If so the best option is to used a carbide (or better) tool at high speed.
Actually, the very best option is to use a water jet like stated above.
Water jet will be expensive for my work. It's similar to FR4, but it has several layers. I will be trying a plug cutter tomorrow, and I hope it works. it should be probably the fastest.
You could try using a jigsaw if you don't need the cuts to be very precise.
Thanks a lot guys. I used a wood plug cutter, and it worked like a charm. thx
