Cylinder-and-piston physics probem
  • Thread starter Thread starter jakeowens
    Physics
In the discussion about the cylinder-and-piston problem, the first law of thermodynamics is applied to determine changes in internal energy and heat flow. The process is identified as isothermal due to the slow volume change from 55 liters to 8 liters, indicating that temperature remains constant. Consequently, the internal energy of the ideal gas does not change, and any work done on the system is balanced by heat flow into the system. For the second scenario involving the gas in a plastic bag, the work done is calculated as 106,050 J, leading to a significant decrease in internal energy. The key takeaway is that understanding the nature of the process—adiabatic versus isothermal—is crucial for solving these thermodynamic problems.
jakeowens
A cylinder-and-piston containing an ideal gas is placed in contact a thermal reservoir. The volume of the gas is very slowly changed from 55 liters to 8 liters as 50 J of work is done on it by an external agency. Determine the change in the internal energy of the gas
and the amount of heat flowing into or out of the system
For this one, I used the first law of thermodynamics. Delta U=Qinto system - W done by system. Since work is done to the system, its minus a negative so Delta U= Q+W. Where do i go from here though? i know the work done, but i don't know the heat flowing in (in because its being compressed) or the change in energy. Do i somehow use the ideal gas law? I am just kind of lost on what i need to do next.
A gas in a thin plastic bag at atmospheric presure receives 9640 J of heat and, in the process, puffs up the bag, increasing its volume by 1.05 m3. By how much is the internal energy of the gas altered?
For this one i used the equation Work done by system= Pressure * delta V. So work done = 1.01x10^5 Pa *1.05m^3 = 106,050 J. Then using the first law of thermodynamics Delta U= 9630J-106050J = -96410J correct?
the second question you have correct.
FOr the first question, the trick is in the phrase "the volume is changed very slowly" from 55 to 8 liters. This is "code" for isothermal process. IF any thermal process is done very slowly, the heat will be able to flow into or out of a gas to keep the gas at the same temperature as its surroundings. If temperature does not change, then internal energy remains constant.
Remember, "very fast" indicates "adiabatic," "very slow" indicates "isothermal." I don't know why all texbooks don't come right out and say that in so many words.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
