I Damping in a coupled pendulum system
The discussion focuses on the effects of increased damping on the frequencies of coupled pendula, drawing an analogy with LC resonators. It suggests that adding a damper in parallel with the spring could influence the system's behavior, particularly affecting the "opposite" mode. Participants are encouraged to explore the implications of introducing arbitrary drag on each pendulum. Understanding these dynamics is presented as fundamental to grasping broader concepts in physics. The insights gained from this analysis are considered applicable across various physics scenarios.
VVS2000
TL;DR Summary
I was going through my old lab experiments ans stumbled upon a coupled pendulum experiment I did few years ago. Now That I have learnt about damping, I was wondering how a damping which would be present in the individual pendulums affect their coupling?
The beat frequency was equal to the difference in frequencies of the two normal modes. What would be the beat frequency in the case of damping present?
From analogy with LC resonators, I think the increased damping will move the two frequencies further apart.
I think you should first think about putting a damper on (in parallel with) the spring. You know intuitively only the "opposite" mode would be affected. Work that through in detail.
Then put an arbitrary drag on each pendulum and work it out.
If you really understand this system you are looking at half of known physics IMHO. We use it over and over.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
