Data delete after power off from my external hard drive type my passport 500 g.b
Disconnecting an external hard drive without properly closing all active connections can lead to data corruption, as seen with the user's external hard drive where all data was deleted. The correct procedure for disconnecting drives involves using the "Safely remove drive" option in the taskbar to prevent such issues. The user resolved their problem by utilizing a shadow user program, similar to Deep Freeze, which treats the external hard drive as part of the main partition, effectively protecting the data.
shmlsur
thanks to read my message
after transfer my document and plug out my external hard " my passport 3.0 500 g.b " all data delete , please help me
Computer science news on Phys.org
unfortunately there's not much you can do to resolve the problem. When you connect an external drive to the system, windows is actively reading and writing to the disk. If you do not close all active connections to the drive and simply disconnect the drive, there is a chance that it will cause a corruption on the external drive. This appears to have happened to your disk.
There isn't really much you can do about this now. All you can do is ensure that you disconnect drives in the correct procedure by using the "Safely remove drive" icon in your task bar.
thank you too much for your advice , i solve the problem , i use a shadow user program " just like a deep freez " , and this program deal with the external hard as a Part of partation C which I Freez it , any way thank u too much for your interest
Well, the date has now passed, and Windows 10 is no longer supported. Hopefully, the readers of this forum have done one of the many ways this issue can be handled. If not, do a YouTube search and a smorgasbord of solutions will be returned. What I want to mention is that I chose to use a debloated Windows from a debloater. There are many available options, e.g., Chris Titus Utilities (I used a product called Velotic, which also features AI to prevent your computer from overheating etc...
I have been idly browsing what Apple have to offer with their new iPhone17. There is mention of 'Vapour cooling' to deal with the heat generated. Would that be the same sort of idea that was used in 'Heat Pipes' where water evaporated at the processor end and liquid water was returned from the cool end and back along a wick. At the extreme high power end, Vapour Phase Cooling has been used in multi-kW RF transmitters where (pure) water was pumped to the Anode / or alternative Collector and...
