DC to AC in micro- and nano- scaled electric circuits
  • Thread starter Thread starter user-000
    Nanotechnology
Converting DC to AC in micro- and nano-scaled electric circuits is not considered a significant problem, as existing technologies like oscillators and H-bridges effectively perform this function. The demand for new devices specifically designed for this conversion in micro- or nano-electronics appears limited. Current solutions are sufficient for the needs of these scaled circuits. Therefore, innovation in this area may not be a priority. Overall, the existing methods adequately address the conversion requirements.
user-000
Is there a problem of converting DC to AC in micro- or nano- scaled electric circuits? Is designing a new device that would perform such function in demand in micro- or nano- electronics?
No.
An oscillator, or an H-bridge, does that job well.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
