DC voltage across the inductor?
Applying DC voltage across an inductor primarily results in a voltage drop across the series internal resistance of the coil, as the reactance term becomes negligible at DC. The impedance of an inductor combines both resistance and reactance, expressed as Z = R + jωL, but at DC, the reactance (jωL) is zero. Consequently, the current through the inductor can be described by the equation i = V/R, assuming R is the only factor affecting the current. If R is zero, as in superconducting conditions, the current would theoretically be infinite, represented as i = Vt/L. In contrast, applying AC voltage introduces frequency-dependent reactance, increasing the perceived resistance as frequency rises.
php
what happens when u apply DC voltage across the inductor? i.e is the voltage drop only across the series internal resistance of the coil? can we just determine this resistance by simply saying: V_supply = I x r(series)? or do we have to include the inductance?
hint: Do you know the impedance of an inductor?
whats an impedance?
do you mean X_L=wL?
V = Ri + L*di/dt
i = (V/R)*(1 - exp(-Rt/L))
If R=0 (superconducting), then
i = Vt/L
Claude
Before we get too far along, I hope you have more in your circuit besides the inductor, otherwise what do you think would happen when you apply a voltage across a coil of wire?
php said:
whats an impedance?
do you mean X_L=wL?
You're on the right track, however you've given only the inductive reactance.
The impedance Z of an inductor includes both real (pure resistance) and imaginary terms (reactance).
Z = R + jX_L = R+ j \omega L
So the voltage across it would be? V = IZ = I (R + j \omega L)
Since you are applying only a DC voltage (no frequency component), what happens to the reactance term?
Most likely the wire will get hot. You are right, at DC the resistance is only the series resistance of the wire.
If you were to apply an AC signal then it is different. As you increase the frequency the perceived resistance to the AC signal would increase. Many small signal inductors are rated at 100MHz. The rating will be something like 300 ohms at 100MHz meaning that to the source, the line the signal is traveling on will look like a 300 ohm resistor. This is in magnitude impedance format, which is the perceived resistance. At slightly over DC the perceived resistance will be near zero ohms, as the frequency increases, so will the perceived resistance. There is a point at which the resistance will reach a maximum and then it will go back down
There are a few simplifications here but the concept is sound.
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
