DDWFTTW: Looking for the least confusing explanation
In summary, the hidden assumption in this discussion is that the ground has a very large inertia relative to the cart and the air. This assumption allows for the cart to receive no work upon it, according to its unchanging rest frame.
  • #106
sophiecentaur said:
The cable is moving relative to both ends ...
The question asks about the rest frame of the straight part of the cable. In that frame the material of the straight part of the cable does not move, and cannot transfer any mechanical energy. Invoking motion relative to some points, which are not at rest in the chosen frame, simply fails to address the question.
sophiecentaur said:
If the cable were to be stretched, that would constitute work / lost energy.
For the purpose of the question you can assume the cable is not being stretched.
Have you missed the hint I gave you in my previous post?
Likes Motore and jbriggs444
  • #107
sophiecentaur said:
That could apply to any rigid part of any mechanism, though.
Not exactly.
A rigid, non-rotating, non-accelerating part cannot be a net source of work. Nor can it be a net sink of work. If that rigid part is moving, it can be a source of work in one place and a sink of work in another. But the net will still come out to zero.
A rigid, non-rotating, non-accelerating part that is at rest cannot be a source or sink of work at all. Not only is the net zero, the work done by/on the part at every interface must be zero (*).
The latter point is, perhaps, the one you meant to make. It is certainly true. I hear no one saying anything different.
(*) If there is relative motion at an interface, work may be done on the target object despite our part not being in motion. For instance, friction can drain kinetic energy. Or force-at-a-distance interactions such as gravity or electrostatic repulsion/attraction can add or remove kinetic energy. One would normally attribute such gains or losses to the interaction rather than to our motionless part.
sophiecentaur said:
Tension in the cable is the same value all along it. The cable is moving relative to both ends
As @A.T. points out, this is relevant to the work done or energy transferred in other frames of reference. In those frames, the cable does zero net work but does act as a conduit through which mechanical energy can flow.
One way to trace mechanical energy flow is to draw a cross-sectional boundary through an object across which you suspect mechanical energy might be flowing. Consider the stress tensor for the object at a point on this boundary. Multiply it by an incremental directed area along the cross section at that point. This will give you a force vector. Multiply by the local [frame-relative] velocity. This will give you a rate of power transfer at that point. Take the surface integral of this quantity across the cross section. That will give you the total power being carried by the object across the cross section.
For a cable at rest you trivially get zero power transferred.
Likes A.T.
  • #108
So you seem to be saying that work is done at one end and at the other end but no work is done at a point on the wire? Is that counter-intuitive? It's something that I could come to terms with. If you look in another frame then work will be done because the cable is not stationary.
  • #109
No. No one is saying that.
For a wire at rest, no work is done at the one end. No work is done at the other end. No energy is transferred through the wire.
The fact that in some other frame, positive work is done on one end, negative work on the other and energy is transferred through the wire is irrelevant. Work is frame variant. Power is frame variant.
One can find invariants if one knows where to look. The net mechanical energy created by the wire is invariant and is zero. The net mechanical energy created by the motor is invariant and is non-zero.
Likes Gleb1964 and A.T.
  • #110
“For a wire at rest” a wire is always at rest in its own frame, isn’t it?
  • #111
Yes. And in motion in other frames. So?
You realize that we can contemplate a wire without adopting its rest frame, right?
  • #112
The word 'net' seems to be the relevant thing to resolve an apparent problem.
jbriggs444 said:
For a wire at rest, no work is done at the one end. No work is done at the other end. No energy is transferred through the wire.I think you must be leaving out . . . .
You say that no work is done at the ends but energy is transferred on to and off the wire because the motor's energy is spinning the propellor. To resolve an apparent paradox, there needs to be a more rigorous definition of work . The winch causes tension on the wire and there is motion of the drum along the wire. That implies (is?) work.
It is pointless to think that nothing is transferred along the wire. The energy involved is known so how is it just "irellevant"?
  • #113
I think the point is that the motor is not only connected to the wire. In the frame where the ground is moving and the wire is not only one of the third law pair of forces is doing work, and it is not the one on the wire.
Likes sophiecentaur
  • #114
Ibix said:
I think the point is that the motor is not only connected to the wire. In the frame where the ground is moving and the wire is not only one of the third law pair of forces is doing work, nd it is not the one on the wire.
I think that is the most useful (and brief) contribution towards clearing up the problem. The ground moves and so does the wire on the drum.
Likes Ibix
  • #115
sophiecentaur said:
.... because the motor's energy is spinning the propellor.
Wrong. We are using the rest frame of the wire, were the wire cannot transfer any mechanical energy. In that frame all the energy the torpedo gets comes from the moving water.
No. If the wire material doesn't move, no force is doing work on it.
It is correct in the rest frame of the wire. You just fail to stick to that frame.
  • #116
The wire on the drum is not where you will find the solution. Think about the forces exerted by the whole motor assembly on other objects. Aside of the wire, what is the motor assembly exerting forces on? Are those forces doing work?
Likes jbriggs444
  • #117
In the rest frame of the cable, no work is done at the ends.
In the rest frame of the cable, the motor's energy is not spinning the propellor. As I recall, you've been asked where the motor's energy is going from the perspective of this frame and have been given some pretty broad hints. But you've never answered.
In the rest frame of the cable, energy from the flowing water is spinning the propellor and providing the propulsive thrust for the torpedo.
In the rest frame of the ground, work is being done by the motor on one end of the cable.
In the rest frame of the ground, power is being transmitted through the cable.
In the rest frame of the ground, work is being done by the cable on the torpedo's propellor.
Pick a frame. Any frame. But stick to it. Don't frame jump without fair warning and appropriate transformation rules. Your statement quoted above involves a frame jump.
A claim that "no energy is transferred" is frame-relative.
A claim that the motor's energy is spinning the propellor is frame-relative.
Those two claims are each true for one frame and false for another. There is no single frame where both are correct. The contradiction you wish to claim does not exist.
  • #118
That is not what I said (or at least meant to say). Work is done but not 'on' the ends if the 'ends' of the wire are taken to be where the wire enters or exits the moving drums. At each end of the wire there is force and there is motion (but not motion of the string). This is just the same as when a car drives up hill or accelerates. Earth stays still but the wheels turn and work is done. You have to allow work to be done somewhere or energy can't be transferred.
This justifies my worry that the 'on or by' adverbs are often a needless confusion in this sort of scenario.
Not broad enough, I'm afraid.
I appreciate that but I have only allowed the drums to move relative to the wire so how am I frame jumping?
I could be struggling with this because there is a causal chain involved with coal being burned on shore and the torpedo is being pulled along through the water. The on shore drum is moving along the wire and the torpedo is moving along the wire. Merely stating a fact about use of frames can hardly change that - can it?
  • #119
This much is not quite incorrect. Just misguided.
This part is flatly wrong.
In the rest frame of the Earth (or, equivalently, the rest frame of the contact patch on the tires) zero work is done by the Earth on the tires. And zero work is done by the tires on the Earth.
The wheels turn, yes. But that does not affect the work done across the interface between tires and road. The work done across that interface is zero.
If you want to look for work done, you will need to look more closely. The wheel is exerting forward force on the frame of the car. Work is being done there. Meanwhile, the axle is exerting torque on the wheel. Work is being done there. Ideally, the net work done on the wheel is zero. In the real world, rolling resistance causes the wheel to dissipate mechanical energy internally, so really, the wheel absorbs positive net work. That is an invariant.
We could chase the energy flow through the drive train to the engine. The engine exerts torque on the drive shaft doing work across that interface. The countering torque is from the motor mounts which do not rotate. So no work is done there. The motor is a net energy source. This is an invariant.
But in the rest frame of the cable, energy is not transferred. Nor is work done on or by the cable.
Work is done somewhere in this frame. I know where. @A.T. knows where. We want you to figure it out.
The supposed justification is lacking.
I will grant you that those adverbs are often unnecessary and are eliminated for brevity. For instance, if a team of horses is pulling a plow through a field and the student is asked for the work is done over the length of a furrow, we are clearly asking for the work done by team on plow.
It would not be amiss if the student multiplied the furrow length by its cross-section, multiplied by the height to which the soil had been raised above its prior resting place and then multiplied by the local acceleration of gravity. That would give the work done by plow on soil and would miss the energy dissipated by friction between plowshare and earth.
Do you understand how work is defined? It appears that you do not.
Work is the vector dot product of the force across an interface and the displacement of the material of the target object at the interface.
In the case of work done by Earth on tires, the tire material at the contact patch has zero displacement parallel to the road. Zero work is done by road on tires.
In the case of work done by tires on Earth, the road material at the contact footprint has zero displacement parallel to the road. Zero work is done by tires on road.
In the case of work done by drum on wire, the wire material at the contact point(s) has zero displacement parallel to the wire. Zero work is done by drum on wire.
In the case of work done by wire on drum, the drum material at the contact point(s) has zero displacement parallel to the circumference of the drum. Zero work is done by wire on drum.
In the rest frame of the wire it is a simple fact that the drum does zero work on the wire.
Nothing that anyone has said here denies the causal chain.
We are looking at energy flows, not causation chains or information flows. They are not at all the same thing.
Energy flows are frame relative. We could talk about momentum flows, angular momentum flows or information flows instead. But we should be clear on which one we are analyzing.
Likes Motore
  • #120
Thanks for your time; it must have been frustrating.It's all down to having a consistent definition of work. I won't waste more of your time looking for 'loopholes'. :smile: It makes more and more sense now.
Likes jbriggs444
  • #121
In my post I used a definition of "work" in terms of the dot product of a particular force times the displacement of the material of the target object at the interface where that force is applied.
It is also possible to define "work" in terms of the dot product of the net force on the target object times the displacement of the target object as a whole.
The former may be called "mechanical work". The latter is called "net work". Mechanical work is the one that is properly suited to tracking mechanical energy flows.
The distinction between the two is crucial when contemplating scenarios involving tires on road or wire on winches. Or, for that matter, Black Birds on lake beds.
If one is dealing purely with rigid non-rotating bodies then the distinction between the two sorts of work is pretty well nil. I managed to skate through school without ever worrying about it.
Likes sophiecentaur
  • #122
But does it make enough sense to you to answer the orignal question?:
A.T. said:
In case A2 (rest frame of the cable), since the motor cannot power the torpedo via a static cable, where does the energy from the motor go to?
Note that I basically gave the answer away when I pointed you to the question:
A.T. said:
But in frames where the Earth is moving, the work done on the Earth is not negligible, compared to the work done on the much smaller object. See for example my question about the Brennan torpedo:
You then started out very well:
sophiecentaur said:
The ground is moving (in the cable frame).
You also got additional hints:
All you have to do is to apply the definition of work:
Likes jbriggs444 and sophiecentaur
  • #123
A.T. said:
And here is a question to ponder: In case A2 (rest frame of the cable), since the motor cannot power the torpedo via a static cable, where does the energy from the motor go to?
The energy goes into accelerating (rotating) the earth forwards and increasing the earth's kinetic energy (with respect to the cable). Since the earth has a huge mass, the rate of acceleration is very tiny. Prior posts already mention work done on earth equals force applied by motor times distance the earth rotates. This work shows up as an increase in kinetic energy of the earth (with respect to the cable). Consider the motor as part of the earth since it is attached to the earth.
I posted about the 1877 Brennan Torpedo in one of the earlier threads (2011) also noting that if the wires were attached to posts, the torpedo would move downstream faster than the stream.
https://www.physicsforums.com/threa...dressing-common-questions.562993/post-3690588
I posted essentially the same thing in a later thread in 2012:
https://www.physicsforums.com/threa...dressing-common-questions.562993/post-3883574
Likes jbriggs444
  • #124
Conflating causation with energy flow is indeed one of the most common mistakes, that leads people to get the DDWFTTW brain teaser wrong, and conclude it's impossible or some sort of perpetuum mobile. Instead of simply applying the definition of work, they go in circles trying to determine what causes what in a mechanical feedback loop.
