hagopbul
- 359
- 37
Summary:: how we can de ice the turbine in case of sudden frezzing like what happened in texas
hello all :
i was watching the news and saw the news talking about frezzing of wind farms in texas state , and losing about 35% of the energy due to that problem
can we use the following methods to de ice the turbine
1 - due to the fact that the turbine is metallic can't we use SAR radar on millimeter rang (300 mhz to 300ghz ) on spacing with the turbine that made stationary wave set up ?
f = (n*v)/2L
f = 300exp06 to 300exp09 hz, n = or >1 , v = 3exp08 m/sec
L = ?
how we can compensate for the refraction in ice ? as we know there is 3 layers
1 atmosphere with density d1
2 ice with density d2
3 metal surface
considering the metal surface is a reflector with 99% efficiency
the ice thickness will give rise to multiply refraction and we have two state of ice the surface in contact with the atmosphere and the inner layer of the ice how we can calculate the wave parameter to achieve highest speed of de icing
2- couldn't we use the idea of spraying some heat storage liquid like (heated)cooking oil or other liquids as a way to de ice the turbine
what should we do to determent the best surface tension of the oil for the purpose of making the period of ice - oil contact as high as possible
3 why salt crystals not effecting in making the ice melt fast is it related to how the crystal refract the light ?
although there is methods to prevent the icing of the turbine that would be another post
how the wandervals force (bond) effecting the above questions ?
another ideas like pizo electric mechanical wave generation like in applying sound waves or creating vibrations in the ice sheet , could it be effective on a few hundred ton building like wind turbine ?
Best
Hagop
hello all :
f = (n*v)/2L
L = ?
3 metal surface
Best
Hagop
