Is Zero Acceleration Proof That an Object Must Be at Rest?
The discussion centers on a physics exam question regarding whether an object with zero acceleration must be at rest. Participants argue that the wording of the question is misleading, as "must" implies absolute certainty, while an object can also move at a constant velocity, making the statement sometimes true. The consensus leans towards the answer being "C: Sometimes true," as zero acceleration does not guarantee rest. The confusion arises from the use of "must," which excludes the possibility of motion. Ultimately, the question is deemed poorly worded, leading to unnecessary complications in understanding the concept.
  • #31
MrAnchovy said:
I think some people are being confused here (not cjl, our posts crossed) - let's use a slightly different question:
"If an object is rotating it must be on fire". Is this statement "sometimes true"? When?
I'm really surprised there was any argument at all following this post.
  • #32
Fredrik said:
Yes, the question is very badly worded, but I think it's still pretty obvious that the person who wrote the question intended C to be the correct answer.
To this I would add that if someone was aware enough of the issue to answer D, it would have been best to ask the teacher to clarify during the test.
  • #33
I disagree. As worded, the answer is very clearly D, and I would not have hesitated (were I in that class) to answer as such. There's nothing about the question that needs clarification.
  • #34
The double, conflicting qualifiers are a poor wording choice regardless of the question's intent.
Edit: the "clarification" by the teacher ("can be" instead of "must") flips the problem over, but doesn't fix it. It should say "is".
  • #35
cjl said:
No, it is false, in the same sense that stating "if y=x^2, must Y be equal to 1" is false. Yes, Y=1 is a possibility, given the constraints of the problem, but it isn't the only possibility, and thus the statement is false.
I assume that you meant to say "if y^2=1 then y=1". This is a sentence, but not a statement (=a sentence that's either true or false). You need a "for all" to turn it into a statement, and there's more than one option, for example:
(a) For all real numbers y, if y^2=1 then y=1.
(b) For all positive real numbers y, if y^2=1 then y=1.​
Statement (a) is false, but statement (b) is true. So you actually made a mistake that's very similar to the one made by the guy who wrote that question.
When the scope of the "for all" that turns this sentence into a statement is a subset of the set of all objects that are on fire.
You could argue that my argument is irrelevant since I'm ignoring the intended meaning of the sentence, but those of you who argued that D is the only correct answer did that too, so if my argument is irrelevant, then so is yours.
  • #36
No, I meant what I said, though I worded it rather poorly. Consider:
Given a function Y=X^2 for any X∈R, Y must be equal to 1
Is this:
a) Always true
b) Sometimes true
c) Never true
The correct answer is c, even though it is clearly possible for Y to be equal to 1 in this problem. Even though x=1 is a possibility, the statement is still false because it contains the word "must".
Likes Merlin3189
  • #37
It strikes me that the original question is logically inconsistent in itself. It is actually unanswerable.
Why bother to try to resolve a badly worded bit of writing when you can spend more useful time in understanding the basics of Physics from the standpoint of Physics?
Likes pbuk
  • #38
Is this:
a) Always true
b) Sometimes true
c) Never true
It's still poorly worded, but I think I can rephrase it correctly this time: "For all real numbers x and y, if y=x2 then y=1".
If this is the statement, the question should only ask if the statement is true or false. (It's false).
Likes sophiecentaur
  • #39
Here's where English or any language doesn't correlate to physical reality, Langauge is imprecise and there's no getting sound that.
  • #40
The more you understand the science behind a question, the more difficult it is to answer it . At the high school level this is really a philosophical question asking you to choose whichever answer allows for the most latitude in the definitions of the words in the question.
Likes Nile Anderson
  • #41
That has NEVER worked for me during a test. Do the best you can was the typical answer...
Likes Merlin3189
  • #42
In my opinion the answer will be D.
  • #43
sachaw said:
"If the object has zero acceleration the object must be at rest"
If an atom is at absolute zero, that is the only time i can conclude "the object MUST be at rest". Therefore my answer is "D", It is never true that an object must be at rest due to zero acceleration.
  • #44
I agree; I would have not hesitated to have chosen D either. Bad wording on your teacher's part.
  • #45
I would have answered D.
To me this sounds like:
##Proposition : [\vec{a}=\vec{0} \implies \vec{v}=\vec{0}]##
And this implication is not true . This proposition is never true.
Obviously the teacher wanted you to understand the significance of acceleration. He probably did not wanted to know if you could solve simple logic problems.
  • #46
answer C
ds(t)/dt=0 does not follow from d2s(t)/dt2
  • #47
I am new here but seriously , you have all seem to complicate the answer to a very simple question. Based on the current phrasing of the question in question, then the very logical answer would be C, it is is the safest bet under these conditions because it can be true that it must be at rest as well as it must be at a constant velocity , saying that the statement is sometimes true factors this in as it allows another condition to follow it having zero acceleration. Wrong ?
  • #48
Mishra consider your proposition , is it truly never true though , can't zero acceleration imply rest , it also can imply constant velocity yes , but look at this Now say I use the following propositions:
p: Acceleration is zero
q: Object at rest
r: Object at constant velocity
p→ (q∨r) , But anytime r is true , q is true ⇒ q∨r≡q, I mean well as far as that goes q∨r≡q≡r≡T, but most importantly , q∨r≡q
If that is so then p→q must be true at some given point. Once more correct me if I am wrong .
  • #49
Yes but is that what we truly define as rest , motion has ceased on atomic levels , up to this day I have seen no proof that scientists utterly understand things on an atomic level , so then we need to apply only Newtonian physics which only really applies to things on a macroscopic level , and let us think about the motion of an atom , the atom and he electrons are such that a great probability exists that once placed in a small area such as condensed in an object , they will either:
i) Move to and fro from a position X
ii) Move from X and possibly eventually return there
These both imply zero displacement and hence zero velocity and so they are at rest by our arbitrary defintions
  • #50
I'm not sure why this is still being debated, but 50 posts about a really badly worded question is definitely too many.
  • #51
I think in trying to find a solution initially , others brought up debatable points
  • #52
Absolutely.
Maths seems to be the best available language that we have for describing physical situations because it is the most highly disciplined. Using 'words' always provides opportunities for misinterpreting questions and other peoples' answers. Mathsphobics beware.
  • #53
Most of the time when kids ask, they are fishing. This time the question was actually badly written. I've had teachers correct a problem in the middle of a test.
  • #54
I have been in this situation several times. I cannot remember exactly what the questions were, but I have always been good at spotting contradictions. It more readily appears in multiple choice questions, where the "simple" answer that is expected (C) is competing with a more rigorously correct answer (D). Sometime in 7th grade I remember deciding to dumb myself down for tests. My math and chemistry teacher Mr. Glickman was scared to hand me and my best friend tests. We would compete to see who could find these "poorly worded questions" first. He actually allowed us to discuss things during tests because he knew we weren't cheating. We were finished with A's long before most other students were finished. The "book smart" ones would never beat us, because they were never taught the "tricks" we figured out ourselves.
Should, could or can instead of "must" resolves the conflict then "C" is the correct answer.
  • #55
No, try my equivalent proposition:
  • A wheel that is rotating should be on fire.
    Is there any reason that a rotating wheel should be on fire? No, the statement is false. Is the statement dependent on any particular set of circumstances? No, the statement is always false.
  • A wheel that is rotating could be on fire.
    Could a rotating wheel be on fire? Yes, the statement is true. Is the statement dependent on any particular set of circumstances? No, the statement is always true.
  • A wheel that is rotating can be on fire.
    Can a rotating wheel be on fire? Yes, the statement is true. Is the statement dependent on any particular set of circumstances? No, the statement is always true.
So what wording can produced the "desired" answer of C?
  • A wheel that is rotating is on fire.
    Is it possible that a wheel can be both rotating and on fire? Yes, the statement can be true. Is the statement dependent on any particular set of circumstances? Yes, the statement is only true when the rotating wheel that is the subject of the statement is on fire: the statement is sometimes true.
Note that the wording in the question "If a wheel is rotating it must be on fire" will never yield C as the correct answer while it starts with "If..."
  • #56
Or a more rigorous analysis: let A be the set of objects with zero acceleration and B be the set of objects at rest.
Statement: If the object has zero acceleration the object must be at rest
Translation: ∀x: x ∈ A → x ∈ B (1)
Counter-example: an object with constant non-zero velocity: x ∈ A is true and so the proposition asserts x ∈ B but x ∉ B so the proposition is false.
Conclusion: (1) is false.
Statement: An object that has zero acceleration is at rest.
Translation: This is ambiguous, it could either mean x ∈ A → x ∈ B (1) as before, or alternatively it could mean x ∈ A ∧ x ∈ B (2).
Example of (2) is false: x is an object with constant non-zero velocity.
Example of (2) is true: x is an object at (continuous) rest.
Conclusion: (2) is sometimes true.
  • #57
The statement is indeed never true.
The answer D is correct and C is false.
Even for an object with zero acceleration and at rest
the statement that the rest condition is implied by the zero acceleration condition is false.
"False implies "never true".
The teacher is wrong. What he perhaps _intended_ to ask was not what he actually asked.
You can quote me on this.
  • #58
Just as I thought I was out...they pull me back in.
Logically, there's no difference between the sentences
If an object has zero acceleration, it must be at rest.
and
If an object has zero acceleration, it is at rest.
They both mean the same thing, "something implies something". Unfortunately it's not clear what that something is. Is it
If v'=0 then v=0.
or
If v'(t)=0 then v(t)=0.
where t has some specific value?
Let's just say that it's the former, to keep things as simple as possible. The sentence "if v'=0 then v=0" doesn't have a truth value. I'll use a simpler example to explain. Consider the sentence x2=1. It doesn't have a truth value, but it can be given one by an assignment of a value to the variable x. If we specify that x represents the number -1, then that truth value is TRUE. If we specify that x represents the number 39, then that truth value is FALSE.
When we write something like x2=1 without having previously assigned a value to x, the intention is usually that the sentence should be interpreted as a part of a slightly longer sentence. That sentence is ##\forall x~~ x^2=1##. This sentence has a truth value only if it's clear from the context what the scope of the "for all" is.
Now let's return to "if v'=0 then v=0". The two obvious ways to assign a truth value to this sentence is a) to completely specify what v is, and b) to add a "for all" to the start of the sentence, and make it completely clear what the scope of that "for all" is. Regardless of which of these options we choose, we run into additional complications. If we choose a), then we must specify a coordinate system, and the truth value of the implication will depend on that choice. If we choose b), then we must specify the scope of the "for all", and the truth value of the implication will depend on that choice.
All these attempts to prove that D is the only right answer are deeply flawed because they ignore all of these issues. There is no way to argue logically that D is the right answer, or that C is the right answer.
  • #59
Been there myself - and delivered an apology to an A Level class for confusing them. Still remained friends with them, though. It's a different matter if a class is after your blood from the start, though.
  • #60
Yes, I think this one has been beaten to death.
  • · Replies 25 ·
  • · Replies 23 ·
