Debunking the hydrogen economy
In summary, the concept of a hydrogen economy relies heavily on the development of renewable energy sources, specifically the use of hydrogen as an intermediary for energy storage. While batteries currently have limitations in terms of energy storage and range, the development of more efficient technology and infrastructure for electric cars could be a viable alternative to hydrogen-powered vehicles. However, there are still concerns about the feasibility and efficiency of a hydrogen economy, particularly in terms of the production and transportation of hydrogen. Further research and advancements are needed in both battery and hydrogen technology to determine the most efficient and sustainable solution for the future of transportation.
  • #106
mheslep said:
The cylinder is exposed to hydrogen roughly half the time the engine is running, regardless of the cycle time, and at high temperature which accelerates embrittlement. I don't think embrittlement qualifies as chemical reaction; http://en.wikipedia.org/wiki/Hydrogen_embrittlement#Process" the process is due to the formation of molecular hydrogen inside flaws in the metal lattice, worsening them. Since all gas is removed during the evacuation stroke perhaps this slows the diffusion of H into the metal lattice vs the rate seen in a static container, but a same time evacuation cycle is not going to pull all of the atoms back out of the lattice.
No doubt some coating or lubricant can help protect the cylinder on an engine designed for H2, but I think it likely unprepared gasoline engines are likely to see damage with extensive H2 burning.
Yeah, I saw that Wiki quote before, but I thought you guys were serious scientists. This is obvious bunk. So many errors, where to begin. Hydrogen is not exposed to the cylinder half the time, try less than 25%. There is no left over hydrogen after combustion, not even hiding in the metal lattice. Hydrogen is far too reactive for any not to combust. All gas is not removed during the exhaust stroke, depending on rpm as much as 22% remains. There has never been proof of any hydrogen embrittlement on any ICE running hydrogen enrichment.
  • #107
RMForbes said:
Yeah, I saw that Wiki quote before, but I thought you guys were serious scientists. This is obvious bunk. ...
H embrittlement is obvious bunk?
You don't know what you are talking about. High vacuum chambers require hours or days depending on the metal to bleed off gas molecules trapped in the metal.
  • #108
Wtf are you talking about there is tons of proof. During the last energy crisis of the 70s there was a @#$% load of work done on hydrogen enrichment and hydrogen embriddlement was a common failure mode. The crank case and/or liner along with the pistons will be affected by hydrogen embriddlement with standard materials, there is no debate. And the engine is exposed to H2 at least 35% of the time. And FYI, the ignition temp of hydrogen is hell of a lot higher than gasoline, about 250K greater IIRC. Do you even know the stoichy equation of combustion in a gasoline engine with hydrogen enrichment?
  • #109
I'm sure hydrogen embrittlement exists, but there has never been any evidence that a ICE running hydrogen enhanced fuel suffered any of these effects. It has not even been an issue for experimental engines running hydrogen as the only fuel. And, I did not say all gases are removed from the metal, only that hydrogen reacts too easily to be left over after combustion. Therefore, how can it cause any ill effects. Your theory that engines using hydrogen enrichment will wear poorly because of hydrogen embrittlement, does not hold water. Actually, hydrogen enhancement has been proven to improve engine wear because carbon deposits are not allowed to form in the cylinder. Carbon deposits don't build up on the piston rings to cause uneven wear to the cylinder walls. Deposits in the cylinder are removed so pre-ignition misfires are greatly reduced. The stresses caused by pre-ignition misfires are far more damaging to metal parts than your theory would ever be.
  • #110
Calm down and just prove it. Show me one documented case that absolutely proves that the engines failure was due to hydrogen embrittlement only. I don't think you can.
  • General Engineering
11K
9K
  • Classical Physics
  • Astronomy and Astrophysics
  • Electrical Engineering
