Decay pressure testing
  • Thread starter Thread starter ddudexyz
    Bluetooth Usb
To conduct effective pressure decay testing lasting 10 minutes with electronic result transmission, detailed information about the setup is crucial. Users are encouraged to specify their existing equipment, including pressure measuring devices and their communication capabilities. Recommendations include using a Programmable Logic Controller (PLC) from major manufacturers like Allen-Bradley, Texas Instruments, or Siemens for data logging. The discussion emphasizes the need for clarity on how results should be logged and presented, whether to a printer or storage device. Providing more specifics will enable more tailored advice for achieving the desired outcome.
ddudexyz
TL;DR Summary
Transference of information electronically to alleviate human error
I want to conduct pressure decay testing that will conduct a decay test lasting 10 mins and once the test has concluded transmit test result electronically to a saved storage location. Any advice?
Welcome to PF.
There are lots of ways to measure and log data. Do you have experience with any such methods and equipment?
Can you link to the datasheet for your pressure measuring equipment? Does it already have some electronic communication port for communicating with it? (USB, Ethernet, Serial/RS-232, etc.)
What kind of PC do you have to read and log the data? What communication ports does it have available?
The more you tell us about your setup, the more we can help you get this up and running soon. :smile:
The entire idea is at ground level right now. Assume I have absolutely nothing to start with. What advice would you give to construct a simple, but effective means by which to obtain the desired result?
To be honest, your response makes no sense. What *exactly* are you trying to do?
Likes russ_watters
In keeping with the "Limited Information Transfer" in this thread, I suggest a Programmable Logic Controller, or PLC as they are often called.
The three major manufacturers are: Allen-Bradley, Texas Instrument, Siemens. Input interfaces available include: On-Off Voltage (AC & DC, Analog Voltage (AC & DC), 4-20mA Current; along with a multitude of sensors from various manufacturers.
You mention Logging. Does this mean to a printer, graphic display, mass storage device (what kind? hard disc drive, Solid State Drive, other?)
So far you are asking on the order of "I want to make marks on paper." That could be a $4000 high speed line printer down to grab a piece of charcoal and draw a line.
For instance you could use a bellows, a pencil, and have the pencil poke a hole in the paper when the pressure gets too low. That meets your stated constraints.
So far, we have no idea what you think you need or how it is to be presented as useful information.
If you want targeted answers, further define the problem and your constraints.
Cheers,
Tom
Likes russ_watters
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
