Decomposition of tensors into irreps (Georgi's book)
In summary, decomposing a tensor product into irreducible representations involves symmetrization, antisymmetrization, and removing traces from the symmetric and anti-symmetric parts. The irreducible representations are symmetric, antisymmetric, and with the traces removed from pairing upper with lower indices. The dimensions of the irreps can be determined by counting the number of independent components after these transformations are applied.
PineApple2
49
Hi. In Georgi's book page 143, eqn. (10.29) he gives an example of decomposing a tensor product into irreps:
[tex]
u^iv_k^j=\frac{1}{2} \left( u^iv_k^j+u^jv_k^i-\frac{1}{4}\delta_k^iu^\ell v_\ell^j-\frac{1}{4}\delta_k^ju^\ell v_\ell^i \right)\\
+\frac{1}{4} \varepsilon^{ij\ell} \left( \varepsilon_{\ell m n}u^m v_k^n + \varepsilon_{kmn}u^m v_\ell ^n \right)\\
+\frac{1}{8} \left( 3 \delta_k^i u^\ell v_\ell^j - \delta_k^j u^\ell v_\ell^i \right)
[/tex]
I have a few novice questions about this.
1. In the first line, he symmetrizes and removes the trace. Looking at the second line, it can be written as [itex] \frac{1}{2} (u^i v_k^j-u^jv_k^i) - \frac{1}{4} \delta_k^i u^\ell v_\ell ^j + \frac{1}{4} \delta_k^j u^\ell v_\ell ^i [/itex] which corresponds to also removing the trace from the anti-symmetric part. Why do we need to also remove the trace from the anti-symmetric part? aren't the irreducible representations - traceless symmetric, anti-symmetric, and trace?
2. Why is the trace [itex] v_j^j [/itex] zero?
3. How do we get the dimensions of the irreps. For example, how do we figure out that the first line corresponds to [itex] \mathbf{\bar{15}} [/itex]?
Thanks.
[tex]
[/tex]
Georgi's upper indices correspond to ##\mathbf{3}##s, while the lower indices are ##\mathbf{\bar{3}}##s. The invariant tensor ##\delta^i_j## contracts a ##\mathbf{3}## index with a ##\mathbf{\bar{3}}## index. So the irreducible representations are symmetric, antisymmetric and with the traces removed from pairing upper with lower indices. But you don't get a symmetric, traceless representation for ##SU(3)##. For instance, the two index symmetric product of ##\mathbf{3}##s is the ##\mathbf{6}## given by (10.22). There's no invariant tensor available to remove the trace.
Perhaps you are confused with orthogonal groups, which have real representations and so the invariant tensor has indices of the same type (both down or both up depending on convention).
So in the first line of the expression you quote, the traces to be removed are those between the upper indices ##i## and ##j## and the lower index ##k##. Note that there is no particular symmetry between the upper and lower indices.
##v^k_j## is assumed to be an irreducible representation (actually the adjoint in particular), so it must be traceless (since it has an upper and lower index).
If we symmetrize in ##ij##, we count ##3\cdot 4/2 = 6## independent components with respect to those indices. There are ##6\cdot 3 = 18## ways to pair this with the lower index ##k##, but we have to subtract the (symmetrized) trace between the upper and lower indices, which removes a total of ##3## terms. So we are left with ##18-3=15## independent components for this combination.
[tex]
[/tex]
Thanks.
If all the components of a tensor [itex]T[/itex] are independent of each other, we say that the tensor is irreducible, i.e., if such tensor has [itex]d[/itex] components then we have a d-vector in (an irreducible) d-dimensional vector space. We write this irreducible representation space as [itex][d][/itex]. This means that the group in question acts on (transforms) such vector by [itex]d \times d[/itex] matrix representation of the group elements. However, in general an arbitrary tensor is reducible, i.e., not all components are independent of each other. Reducible tensor can be decomposed (in a group invariant way) into irreducible tensors by the processes of symmetrization, antisymmetrization and contraction between upper and lower indices, i.e., subtracting all possible traces.
Okay, let us talk about [itex]SU(3)[/itex]. Consider the antisymmetric tensor [itex]T^{[ij]}_{k} = T^{ij}_{k} - T^{ji}_{k}[/itex]. It has [itex]3(\frac{1}{2}(2)(3)) = 9[/itex] components but it is not irreducible. To reduce it, we impose the 3 trace relations [itex]T^{[ij]}_{j}=0[/itex]. So, we end up with [itex]9-3=6[/itex] independent components. But 6 is exactly the number of independent components in a symmetric tensor [itex]S_{(kl)}[/itex]. This means that traceless antisymmetric mixed tensor [itex]\hat{T}^{[ij]}_{k}[/itex] is equivalent to a symmetric rank-2 tensor. This is exactly what you have done in the second line of your equation. In practise, we actually never need to subtract a trace from the antisymmetric part because by subtracting the trace from the symmetric part we also have to balance our equation, i.e., we have to add what we have subtracted and this added piece will make the antisymmetric part traceless (see below).
Now, let us count the number of independent components in the traceless symmetric tensor [itex]T^{(ij)}_{k}[/itex] (this is the same tensor in the first line of your equation). Again, symmetry implies that for each [itex]k[/itex], we have [itex]\frac{1}{2}(3)(4) = 6[/itex] components, i.e., a total of [itex]3 \times 6 = 18[/itex] components in the symmetric mixed tensor. Then, the 3 trace relations [itex]T^{(ij)}_{i}=0[/itex] reduces the number to [itex]18-3=15[/itex] independent components. If you associate upper indices with the conjugate representation, then [tex]T^{(ij)}_{k} \equiv \frac{1}{2} u^{(i}v^{j)}_{k} - \frac{1}{8} \delta^{(i}_{k}v^{j)}_{n}u^{n} \in [\bar{15}] .[/tex]
Now, the number of components of the totally symmetric (irreducible) [itex]SU(3)[/itex] tensor [itex]T^{(k_{1} k_{2} \cdots k_{m})}[/itex] is [itex]\frac{1}{2}(m+1)(m+2)[/itex]. Therefore, the tensor [itex]T^{(k_{1} k_{2} \cdot k_{m})}_{(j_{1} j_{2} \cdots j_{n})}[/itex] has [itex]\frac{1}{4}(m+1)(m+2)(n+1)(n+2)[/itex] components. The number of components of the corresponding (traceless) irreducible tensor [itex]\hat{T}^{(\cdots)}_{(\cdots)}[/itex] will be less than that of [itex]T^{(\cdots)}_{(\cdots)}[/itex] by the number of independent components in the reduced-rank tensor [itex]T^{(k_{1} \cdots k_{m-1})}_{(j_{1} \cdots j_{n-1})}[/itex], i.e., the dimension of the space of traces:
[tex]\mbox{dim}\left( \hat{T}^{(k_{1} \cdots k_{m})}_{(j_{1} \cdots j_{n})} \right) = \mbox{dim}\left( T^{(k_{1} \cdots k_{m})}_{(j_{1} \cdots j_{n})} \right) - \mbox{dim}\left( T^{(k_{1} \cdots k_{m-1})}_{(j_{1} \cdots j_{n-1})} \right) ,[/tex] or
[tex]\mbox{dim}(m,n) = \frac{1}{4}(m+1)(m+2)(n+1)(n+2) - \frac{1}{4}m(m+1)n(n+1) = \frac{1}{2}(m+1)(n+1)(m+n+2) .[/tex]
As for why [itex]v^{i}_{j}[/itex] is traceless: well it is (1,1) irreducible tensor. So, by the above relation of the dimension you see that [itex]v^{i}_{j}[/itex] belongs to the adjoint representation [itex][8][/itex] which is traceless by construction. Do you recall the relation [itex][3] \otimes [\bar{3}] = [8] \oplus [1][/itex]? In tensor language, we take the tensor product of the fundamental representation [itex]\phi^{i}[/itex] with its conjugate representation [itex]\phi_{j}[/itex] and subtract the invariant trace: [tex]\phi^{i} \otimes \phi_{j} = \left( \phi^{i} \ \phi_{j} - \frac{1}{3} \ \delta^{i}_{j} \ \phi^{n}\phi_{n}\right) + \frac{1}{3} \ \delta^{i}_{j} \ \phi^{n}\phi_{n} .[/tex] So, your [itex]v^{i}_{j}[/itex] is just [tex]v^{i}_{j} = \phi^{i} \ \phi_{j} - \frac{1}{3} \ \delta^{i}_{j} \ \phi^{n}\phi_{n} ,[/tex] which is traceless and has 8 independent components, i.e., it belongs to the adjoint representation [itex][8][/itex].
Finally, let me do what I should have done first. Notice first that [itex]u^{i}v^{j}_{k} \in [3] \otimes [8][/itex], i.e. it is a reducible tensor. So, let us decompose it into irreducible parts. First, we split the tensor into symmetric and antisymmetric tensors:
[tex]u^{i}v^{j}_{k} = \frac{1}{2} u^{(i}v^{j)}_{k} + \frac{1}{2} u^{[i}v^{j]}_{k} .[/tex] To make the symmetric part traceless, we subtract (and add) the symmetric combinations of traces
[tex]u^{i}v^{j}_{k} = T^{(ij)}_{k} + \frac{1}{2} u^{[i}v^{j]}_{k} + \frac{1}{8}\delta^{(i}_{k}v^{j)}_{n}u^{n} , \ \ (1)[/tex] where [itex]T[/itex] is the traceless symmetric tensor
[tex]T^{(ij)}_{k} = \frac{1}{2} u^{(i}v^{j)}_{k} - \frac{1}{8}\delta^{(i}_{k}v^{j)}_{n}u^{n} \in [15]. \ \ \ \ (2)[/tex]
Now, in Eq(1) we use the identity (which you can verify easily)
[tex]\delta^{(i}_{k}v^{j)}_{n} = -2 \delta^{[i}_{k}v^{j]}_{n} + 3 \delta^{i}_{k}v^{j}_{n} - \delta^{j}_{k}v^{i}_{n} ,[/tex] and arrange the terms:
[tex]u^{i}v^{j}_{k} = T^{(ij)}_{k} + T^{[ij]}_{k} + \frac{3}{8}\delta^{i}_{k}v^{j}_{n}u^{n} - \frac{1}{8}\delta^{j}_{k}v^{i}_{n}u^{n} ,[/tex] where we have defined the following traceless antisymmetric tensor
[tex]T^{[ij]}_{k} = \frac{1}{2} u^{[i}v^{j]}_{k} - \frac{1}{4}\delta^{[i}_{k}v^{j]}_{n}u^{n} .[/tex] This can be rewritten as
[tex]T^{[ij]}_{k} = \frac{1}{4} \epsilon^{ijl}S_{(kl)} \in [\bar{6}] , \ \ \ (3)[/tex]
where
[tex]S_{(kl)} = \epsilon_{kmn}u^{m}v^{n}_{l} + \epsilon_{lmn}u^{m}v^{n}_{k} . \ \ \ (4)[/tex] Now, if you put (2), (3), and (4) in (1), you obtain the equation you wrote.
After all that, we finally proved
[tex]3 \times 8 = 15 + \bar{6} + 3 .[/tex]
Sam
Likes dextercioby, nrqed, jim mcnamara and 1 other person
I see, thanks. So is it correct to say that the irreducible representations need to be traceless with respect to upper and lower indices, because otherwise the invariant tensor ##\delta^i_j## will contract them into a smaller dimensional representation, which would mean that they were not irreducible in the first place? and is that also the reason that ##v^j_j## is zero, otherwise it would be contracted into a singlet?
Exactly. If we can use ##\delta^i_j## to pull a singlet out of an expression, then the expression was in a reducible representation.
Thanks!
@samalkhaiat: Thank you very much for the detailed post, that is helpful. However, I don't understand a few things: how do you know in eqn. (2) that the coefficient is ##-\frac{1}{8}##? Also, how do you know that you should use the relation ##\delta_k^{(i}v_n^{j)}=-2\delta_k^{[i}v_n^{j]}+3\delta_k^iv_n^j-\delta_k^jv_n^i## and not some different relation between ##\delta_k^{(i}v_n^{j)}## and ##\delta_k^{[i}v_n^{j]}##? I guess the answer is that you are looking (both in this case and in the case of the ##1/8##) for such linear combinations that would eventually give traceless combinations. But how do you see these combinations at the stage where you have written it?
You are asking about trivial algebra.
1) Write [tex]T^{(ij)}_{k} = \frac{1}{2} u^{(i}v^{j)}_{k} + a \ \delta^{(i}_{k}v^{j)}_{n}u^{n} .[/tex] Now, the demand that this symmetric tensor is traceless uniquely determine the value of the constant [itex]a[/itex]: [tex]T^{(kj)}_{k} = 0 = \frac{1}{2} u^{k}v^{j}_{k} + 4 \ a \ v^{j}_{n}u^{n} , \ \ \Rightarrow \ \ 8 \ a = -1 .[/tex]
2) Write [tex]\delta^{(i}_{k}v^{j)}_{n} = a \ \delta^{[i}_{k}v^{j]}_{n} + b \ \delta^{i}_{k}v^{j}_{n} + c \ \delta^{j}_{k}v^{i}_{n} . \ \ (2)[/tex] Now, if you contract [itex](i)[/itex] with [itex](n)[/itex], you get [itex]a + b = 1[/itex]. And contracting [itex](j)[/itex] with [itex](n)[/itex] gives [itex]c - a = 1[/itex]. And that is all, you can not get more information from (2). However, as in (1), the demand [itex]T^{[kj]}_{k} = 0[/itex] gives you [itex]a = -2[/itex] which in turn leads to [itex]b = 3[/itex] and [itex]c = -1[/itex]
Okay, here is another exercise for you. Decompose the tensor [tex]u^{i}v^{jk} \in [3] \otimes [6] ,[/tex] into [itex]SU(3)[/itex]-irreducible parts.
Likes dextercioby
Here is my trial. Please let me know if there is a better method to use.
In this case, we have only upper indices, which we should symmetrize / anti-symmetrize, and not require being traceless. So,
[tex]
T^{ijk}=u^iv^{jk}=T^{(ijk)}+T^{[ijk]}
[/tex]
now
[tex]
T^{(ijk)} = \frac{1}{6}(u^iv^{jk}+u^iv^{kj}+u^jv^{ik}+u^jv^{ki}+u^kv^{ij}+u^kv^{ji})
[/tex]
now we assume that ##v^{ij}=v^{ji}## since this is the ##\mathbf{6}##, which must be symmetric (otherwise it would have 9 deg. of freedom), using that we have
[tex]
T^{(ijk)}=\frac{1}{3}(u^iv^{jk}+u^jv^{ik}+u^kv^{ij})
[/tex]
this has dimension ## \frac{5!}{3! 2!}=10##. Now consider the anti-symmetric part. anti-symmetrize each time with respect to a different pair of indices.
[tex]
T^{[ijk]}=\frac{1}{3} (\varepsilon^{ij\ell}\varepsilon_{\ell mn}u^mv^{nk} + \varepsilon^{ik\ell}\varepsilon_{\ell mn}u^mv^{jn} + \varepsilon^{jk\ell}\varepsilon_{\ell mn}u^iv^{mn})
[/tex]
now the last term vanishes because of the symmetry of ##v^{mn}##. I am not sure how to calculate the dimension of the first two terms. Could I say that each of them is an anti-symmetric tensor in two of the indices, which is 3 deg. of freedom, and multiplied by the 3 deg. of the remaining index gives 3x3=9. I should get 8, but the tensor with only upper indices should not be traceless.
You have made few fundamental mistakes:
For a general rank-3 tensor [itex]T^{ijk}[/itex], we have
[tex]T^{(ijk)} + T^{[ijk]} = \frac{2}{3!} (T^{ijk} + T^{jki} + T^{kij}) \neq T^{ijk}.[/tex]
In our case, since [itex]T^{ijk} = T^{ikj}[/itex], then [itex]T^{[ijk]} = 0[/itex]. So, we should try
[tex]T^{ijk} = T^{(ijk)} + a \ T^{[ij]k} + b \ T^{[ik]j} . \ \ \ (1)[/tex] Then, [tex]T^{ijk} = T^{ikj} \ \ \ \Rightarrow \ a = b.[/tex] So, the last two tensors in (1) are just symmetric combination of the same irreducible tensor. In order to find the constant [itex]a[/itex], we write (1) explicitly in terms of [itex]T^{ijk}=u^{i}v^{jk}[/itex]:
[tex]T^{ijk}= (\frac{1}{3} + 2a) T^{ijk} + (\frac{1}{3} - a) T^{jki} + (\frac{1}{3} - a) T^{kij} .[/tex] This is true if and only if [itex]a = 1/3[/itex].
Now, since [itex]T^{(ijk)}[/itex] is irreducible, it belongs to the representation space [itex](3,0)[/itex], which has dimension: [tex]\mbox{dim}(3,0) = (1/2)(3+1)(3+2)=10.[/tex] But the original tensor [itex]T^{ijk}=u^{i}v^{jk}[/itex] has [itex]18[/itex] components. Therefore, [itex](T^{[ij]k} + T^{[ik]j})[/itex] must belong to the (traceless) adjoint representation [itex][8][/itex]. To see this, we write
[tex]T^{[ij]k} = u^{i}v^{jk}- u^{j}v^{ik} = ( \delta^{i}_{m}\delta^{j}_{n} - \delta^{j}_{m}\delta^{i}_{n}) u^{m}v^{nk},[/tex] or
[tex]T^{[ij]k} = \epsilon^{ijl} \epsilon_{lmn}u^{m}v^{nk} \equiv \epsilon^{ijl} \Gamma^{k}_{l} .[/tex] Similarly [tex]T^{[ik]j} = \epsilon^{ikl} \Gamma^{j}_{l} .[/tex] Notice that [tex]\mbox{Tr}(\Gamma) = \Gamma^{k}_{k} = \epsilon_{mnk}u^{m}v^{nk} = 0 .[/tex] Thus [itex]\Gamma[/itex] is an irreducible tensor in the adjoint representation [itex](1,1) = [8][/itex]:
[tex]\mbox{dim}(1,1) = \frac{1}{2} (1+1)(1+1)(1+1+2) = 8.[/tex] So you finally have
[tex]u^{i}v^{jk} = T^{(ijk)} + \frac{1}{3} \left( \epsilon^{ijl}\ \Gamma^{k}_{l} + \epsilon^{ikl} \ \Gamma^{j}_{l} \right) .[/tex] :smile:That is the long way to prove [tex]3 \times 6 = 10 + 8 .[/tex]
Good luck
Sam
Likes dextercioby
Hi. Thank you for the detailed answer, that helped me understand. I have a few further questions please. You found the dimension of the ##\mathbf{8}## as the dimension of the traceless antisymmetric tensor ##\Gamma^{j}_{l}##. and I understand that the tensor ##\varepsilon^{ikl}## doesn't matter for that calculation since it's invariant. Do you have a way of figuring out the dimension directly from the expression ##\epsilon^{ijl} \epsilon_{lmn}u^{m}v^{nk}## which has only upper indices?
Also, is there a general way to write any irreducible tensor only in terms of epsilon and delta tensors? how would you write, for example, ##T^{(ijk)}## using that? or in a different case ##T^{[ijkl]}##?
PineApple2 said:
Hi. Do you have a way of figuring out the dimension directly from the expression ##\epsilon^{ijl} \epsilon_{lmn}u^{m}v^{nk}## which has only upper indices?
Dimension of what? The 9-component tensor [itex]T^{[ij]k} = \epsilon^{ijl} (\epsilon_{lmn} u^{n}v^{kn})[/itex] is still reducible. The dimension of the irreducible subspace is given by the traseless part [itex](\epsilon_{lmn} u^{n}v^{kn})[/itex].
I don’t know what you mean. You can not obtain a lower rank tensor from irreducible tensor. But you can write [tex]T^{(ijk)} = \frac{1}{6} (\delta^{i}_{l}\delta^{j}_{m}\delta^{k}_{n} + \cdots ) T^{lmn} ,[/tex] which means that you are isolating [itex]10[/itex] independent components from the [itex]27[/itex] components. Symbolically; [tex]T^{(10)} \sim (\delta \delta \delta) T^{(27)} .[/tex] Similarly, in 3-dimension, you can use the determinant identity for [itex]\epsilon^{ijk}\epsilon_{lmn}[/itex] to write [tex]T^{[ijk]} = \frac{1}{6} \epsilon^{ijk}( \epsilon_{lmn} T^{lmn}) = \epsilon^{ijk} [1],[/tex] which means that a one component tensor (i.e., scalar) is obtained from the [itex]27[/itex]-component tensor [itex]T^{ijk}[/itex]: [itex]T^{(1)} \sim (\epsilon) T^{(27)}[/itex].
In 3-dimension [itex]T^{[ijkl]}=0[/itex], because the indices run from 1 to 3.
Look, you can understand this stuff by doing more examples and relating them to the representation matrices of the group algebra. Another nice and important decomposition is [tex][3] \otimes [3] \otimes [3] = [10] \oplus [1] \oplus [8] \oplus [8] .[/tex] So, have a go: write [itex]T^{ijk}=q^{i}q^{j}q^{k}[/itex], and show that
[tex]
q^{i}q^{j}q^{k} = T^{(ijk)} + \frac{1}{6} \epsilon^{ijk}(\epsilon_{lmn}q^{l}q^{m}q^{n}) + \frac{1}{3} \epsilon^{ijl}\Lambda^{k}_{l} + \frac{1}{3}\epsilon^{ikl}\Gamma^{j}_{l} ,
[/tex]
where,
[tex]\Lambda^{k}_{l} = \epsilon_{lmn}( T^{mnk} + T^{knm}) \in [8] ,[/tex]
[tex]\Gamma^{j}_{l} = \epsilon_{lmn} ( T^{mjn} + T^{jmn}) \in [8] .[/tex]
I will help you, if you get stuck. Good luck.
Likes dextercioby
I get this decomposition:
[tex]
T^{ijk}=T^{(ijk)}+T^{[ijk]}+\frac{4}{3}T^{(i[j)k]}+\frac{4}{3}T^{[i(j]k)}
[/tex]
is that right? because the last two terms don't match to your last two terms. For example
[tex]
\frac{4}{3}T^{(i[j)k]}=\frac{4}{3}\cdot\frac{1}{4}(T^{ijk} -T^{ikj}+T^{jik}-T^{jki})=\frac{1}{3}(\epsilon^{jk\ell}\epsilon_{\ell mn}T^{imn}+\epsilon^{ik\ell}\epsilon_{\ell mn}T^{jmn})
[/tex]
which is not equal to either your third or your fourth term (even though close).
[tex]
[/tex]
[tex]
[/tex]
Eleven months is a long time to spend on that problem, don’t you think?
You could be right, but I don’t follow your notations. Any way, start with the identity
[tex]T^{(abc)} + T^{[abc]} = \frac{1}{3} \left( T^{abc} + T^{cab} + T^{bca} \right) .[/tex]
Rewrite the above as
[tex]T^{abc} = T^{(abc)} + T^{[abc]} + \frac{1}{3} \left(T^{abc} - T^{bca}\right) + \frac{1}{3} \left(T^{abc} - T^{cab}\right) .[/tex]
Now, add [itex]\frac{1}{3}(T^{bac} - T^{cba})[/itex] to the third term (to make it antisymmetric in [itex](ac)[/itex]), and subtract it from the fourth term to make it antisymmetric in [itex](ab)[/itex]. Okay, I do the third term for you and you do the fourth.
[tex]
\begin{align*}
\mbox{third term} &= \frac{1}{3} \left( \delta^{a}_{m} \delta^{c}_{n} - \delta^{a}_{n} \delta^{c}_{m} \right) \left( T^{mbn} + T^{bmn} \right) \\
&= \frac{1}{3} \epsilon^{acl}\epsilon_{lmn} \left( T^{mbn} + T^{bmn} \right) \\
&= \frac{1}{3} \epsilon^{acl} \Gamma_{l}^{b} .
\end{align*}
[/tex]
Notice that [itex]\Gamma_{b}^{b} = 0[/itex]. Thus, [itex]\Gamma^{a}_{c} \sim [8][/itex].
Likes dextercioby
where
Hello. I just came across this post. I understand how the 2nd term in (4) is to equivalent to the 1st term in the 1st equation i.e. uivjk - ujvik = εijlεlmnunvmk = (δimδjn - δjnδim)umvnk but I am having a mental block regarding how the first term in (4) is equivalent to the 2nd term in the first equation. Thanks.
Try to use the identity
[tex]\epsilon^{ijl}\epsilon_{kmn} = - \begin{vmatrix} \delta^{i}_{k} & \delta^{i}_{m} & \delta^{i}_{n} \\ \delta^{j}_{k} & \delta^{j}_{m} & \delta^{j}_{n} \\ \delta^{l}_{k} & \delta^{l}_{m} & \delta^{l}_{n} \end{vmatrix}. [/tex]
I am not sure about the minus sign in front of the determinant. Please check.
Likes dextercioby
Perfect. Thank you!
FAQ: Decomposition of tensors into irreps (Georgi's book)
What is the concept of decomposition of tensors into irreps?
The decomposition of tensors into irreps, also known as irreducible representations, is a mathematical technique used to break down a tensor into simpler, irreducible components. It is based on the idea that any tensor can be expressed as a combination of irreducible representations, which are the building blocks of a given symmetry group.
Why is decomposition of tensors into irreps important in physics?
In physics, symmetries play a crucial role in understanding the behavior of physical systems. The decomposition of tensors into irreps allows us to analyze and classify the symmetries present in a system, providing insight into its properties and dynamics. It is also used in the development of theoretical models and in solving equations of motion.
What is the significance of Georgi's book on decomposition of tensors into irreps?
Georgi's book, "Lie Algebras in Particle Physics", is a seminal work in the field of particle physics. It provides a comprehensive and rigorous treatment of the decomposition of tensors into irreps, which is essential for understanding the underlying symmetries and dynamics of subatomic particles. It has been widely used as a reference for both students and researchers in the field.
Is the decomposition of tensors into irreps a general method or specific to certain types of tensors?
The decomposition of tensors into irreps is a general method that can be applied to any type of tensor, as long as it is related to a symmetry group. This includes tensors in classical mechanics, quantum mechanics, and field theory. However, the specific techniques and calculations may vary depending on the type of tensor and the symmetry group involved.
How is the decomposition of tensors into irreps related to group theory?
The decomposition of tensors into irreps is closely related to group theory, as it involves the study of symmetry groups and their representations. Group theory provides a mathematical framework for understanding symmetries, and the decomposition of tensors into irreps is a powerful tool for applying group theory to physical systems. It allows us to classify and analyze the symmetries present in a system, and to make predictions about its behavior.
