Deducing the volume of an elliptical cone
  • Thread starter Thread starter yaakob7
    Cone Volume
yaakob7
Here again
Find the volume of a right elliptical cone with an elliptic base with semi-axes a and b and heigh h
So: \frac{x^2}{a^2}+\frac{y^2}{b^2}=1
That's what I have, but answer should be:
V=\frac{1}{3}abh\pi
I've checked it all over again like 10 times, but I can't find the mistake. If you can see it I'd be grateful
To tell you the truth, I can 't bring myself to slog through all your steps. But I have a question for you. Have you had change of variables in double integrals yet? For example, do you know how to show the area of the ellipse $$\frac {x^2}{a^2}+\frac{y^2}{b^2}=1$$ is ##\pi a b## by mapping the ellipse to a circle? The reason for my asking is that if you have studied that, a much easier way to do the problem is to use the elliptical cross-sections. You can figure out the equation of the ellipse cross section at height ##z## for ##0\le z \le h## and either use the above formula or develop it with the appropriate change of variables.
I know how to make an implicit differentation but, I can't do that to an intregal expression.
What I asked you has nothing to do with implicit differentiation. Just tell me this: Are you allowed to use the area formula ##\pi ab## for your standard xy ellipse area as a given? If the answer to that is yes, then figure out the equation of the elliptical cross section of your cone at height ##z## for ##0\le z \le h## and use that formula for its area. Then you can integrate the elliptical cross section area as a function of z to get the volume.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
