MHB Dee Gayle's Question about Melodies in Facebook
  • Thread starter Thread starter Sudharaka
The discussion centers on calculating the number of simple eight-note melodies using one octave without sharps or flats. The initial calculation suggests that with repetition allowed, the total combinations are 8^8, resulting in 16,777,216 melodies. However, a participant notes that considering intervals could lead to a much larger figure, approximately 78 billion. The conversation highlights the difference between counting notes and considering musical intervals in melody creation. The topic emphasizes the complexity of melody generation beyond simple note selection.
Sudharaka
MHB
Dee Gayle on Facebook writes:
HELP! How many simple eight note melodies are possible using only 1 octave with no sharps/flats (8 notes)? Explain each step and show the calculation.
the answer should be in the billions..I believe the first part is simply 8^8 but I don't know what else I need to multiply to come up with the correct answer..
Mathematics news on Phys.org
Hi Dee, :)
Yes for the first choice you have 8 notes to choose from, for the second note you have again 8 notes to choose from and so on. So from the Rule of Product we get, \(8^8=16777216\). Here we are assuming that we are only playing one note at a time and that repetition of notes are okay.
Hmmmm, I thought the answer would me more complicated than that, because 8 notes with 12 intervals = 78,364,164,096 (according to research online), so I assumed since there are only 4 less intervals, my answer should also be in the billions. Also, the subject is statistics. Thanks
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
