Definite integral with x^2+c in the denominator
In summary, a definite integral with x^2+c in the denominator is a mathematical expression for finding the area under a curve defined by the function f(x) = x^2+c. It can be solved using the substitution or partial fractions method and has many real-world applications, such as calculating volume and solving differential equations. Some special cases include when c=0 or when c is a negative number, which can lead to imaginary solutions. These integrals are commonly used in physics and engineering to solve problems involving varying forces and accelerations.
Hypatio
151
solve the definite integral
[tex]\int_{2.6}^{5.5} \frac{1}{x^2+9}dx[/tex]
ln(5.5^2+9)-ln(2.6^2+9) doesn't seem correct
Can you show your steps in getting that solution? What did you get for the antiderivative of the integrand?
If you take the derivative of log(x^2+9) you will not get 1/(x^2+9) (at least if you don't forget the chain rule). You need a trig substitution to do that integral.
FAQ: Definite integral with x^2+c in the denominator
What is a definite integral with x^2+c in the denominator?
A definite integral with x^2+c in the denominator is a mathematical expression that represents the area under a curve, where the curve is defined by the function f(x) = x^2+c. This type of integral is also known as a rational function integral.
How do you solve a definite integral with x^2+c in the denominator?
To solve a definite integral with x^2+c in the denominator, you can use the substitution method or the partial fractions method. The substitution method involves substituting a new variable for x, while the partial fractions method involves breaking down the rational function into simpler fractions.
What is the importance of using definite integrals with x^2+c in the denominator?
Definite integrals with x^2+c in the denominator are important in mathematics because they allow us to calculate the area under a curve, which has many real-world applications. They are also used in finding the volume of irregular shapes and in solving differential equations.
Are there any special cases when solving a definite integral with x^2+c in the denominator?
Yes, there are special cases when solving a definite integral with x^2+c in the denominator. One such case is when c=0, in which case the integral simplifies to the basic function f(x) = x^2. Another special case is when c is a negative number, which can lead to imaginary solutions.
How can definite integrals with x^2+c in the denominator be used in real-life situations?
Definite integrals with x^2+c in the denominator have various real-life applications. For example, they can be used to calculate the amount of fluid in a container with a curved bottom, or to find the work done by a varying force. They are also used in physics to determine the displacement of an object under a varying acceleration.
9K
