I Degrees of Freedom in Lagrangian Mechanics for a Fractal Path
In Lagrangian mechanics, a degree of freedom along a tame curve like a parabola is straightforwardly one. However, the concept becomes complex when considering space-filling curves, as not all motions are feasible along these paths. The discussion raises the question of whether a fractal's non-integer dimension implies a non-integer degree of freedom, particularly when motion is confined to a nowhere differentiable curve. The boundary of the Mandelbrot Set, with a Hausdorff Dimension of 2, complicates the understanding of degrees of freedom, suggesting they may still be effectively one. Additionally, the inability to compute certain differentials along these curves introduces a geometric ambiguity reminiscent of the Heisenberg Uncertainty Principle.
Pikkugnome
TL;DR Summary
Degree of freedom along a strange curve from lagrangian mechanics point of view.
Degree of freedom along a parabola, or any such tame curve, is one from lagrangian mechanics point of view. It makes sense. However how does degree of freedom accompany a space filling curve. Intuitively degree of freedom is not two, since not all motions are possible along the curve. How would lagrangian mechanics work on a such curve. A fractal can have a non integer dimension, would that make its degree of freedom also a non integer.
Mathematics news on Phys.org
How does Lagrangian mechanics work if motion is confined to a curve which is nowhere differentiable, as a fractal curve almost certainly is?
That's an interesting question.
The boundary to the Mandelbrot Set has a Hausdorff Dimension of 2 (as demonstrated here - jstor.org). That's an integer - but still a problem because it's the "wrong" integer. (The standard dimension of a curve enclosing an area is one.). Moreover, I expect that given any complex (r,i) coordinate on that curve, a dr and di (or dx,dy if you prefer) can be determined. If that's true, then the degrees of freedom would seem to be solid equal to one.
But it is also interesting if the dr,di cannot be computed. It would a geometric example of something inherently undefined - reminiscent of HUP.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
