B Delta-v from Lagrange points to lunar surface?
The discussion focuses on the delta-v requirements for traveling from Earth-Moon Lagrange points to the lunar surface. Participants express difficulty in finding delta-v maps that include Lagrange points and seek software for visualization and calculations. Kerbal Space Program is mentioned as a potential tool, although it does not model Lagrange points unless modified with the Principia mod. Projectrho is highlighted as a valuable resource for delta-v maps and mission planning. Overall, the conversation emphasizes the need for better resources and tools to calculate delta-v from Lagrange points.
Treva31
TL;DR Summary
What is the delta-v requirements from each of the Earth-Moon lagrange points to landing on the lunar surface?
What would be the best software I could use to visualise and calculate that kind of thing?
Thanks.
Astronomy news on Phys.org
What research have you done on this so far? What have you found?
I have found delta-v maps but none of them include Lagrange points.
I have no idea how to calculate it. Any calculations I see are for orbits, which a lagrange point is not an orbit right?
I'm not sure if (or which) simulators include lagrange points either.
I will try Kerbal I guess..
I am happy to work it out I just don't know where to start.
Ah Kerbal doesn't model for Lagrange points :frown:
If I put your subject line "Delta-v from Lagrange points to lunar surface?" into google I get this which has many delta-v maps that includes Lagrange points.
You might see "projectrho" popping up a lot in that search, that is the "Atomic Rockets" resource for SciFi writers and game designers who wants to get the science right. There is a ton of good stuff in there, for instance the collection of delta-v maps for mission planning.
It does if you add the Principia mod.
Likes Treva31, phinds and berkeman
Ah cool thanks!
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
