Density of standing waves in a cavity
The density of standing waves in a cavity is described by the formula G(f)df = (8πf²/c³)df, which raises questions about its relevance to wave density. Some participants express confusion over the formula's appearance and its connection to density concepts. Clarifications indicate that adjustments to the formula can reveal its relationship to density more clearly. The discussion emphasizes the need for a deeper understanding of the formula's derivation and implications. Overall, participants seek to reconcile the formula with conventional density definitions in wave mechanics.
asdf1
Why is the density of standing waves in a cavity
G(f)df=((8*pi*f^2)/(c^3))*df?
Also that formula looks weird... doesn't look like it has anything to do with density...
? can somebody please help?
it relates to density afrer u change a bit in the formula itself.
thats not true answer
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
