Dependent vs. Indepenent sources?
  • Thread starter Thread starter JLR
    Sources
Dependent sources cannot be treated as open or short circuits because they are inherently linked to other circuit parameters and cannot be independently deactivated. Unlike independent sources, which can be set to zero to simplify analysis, dependent sources rely on the behavior of other circuit elements, making it impossible to isolate them without losing the integrity of the model. When measuring circuit resistance, even with zero input to their controlling elements, the response of dependent sources remains unpredictable due to their reactive nature. This complexity is essential for accurately modeling components like transistors, as turning off a dependent source would compromise the overall circuit analysis. Thus, dependent sources must always be considered in the context of the entire circuit.
JLR
Dependent vs. Indepenent sources!??...
Can anyone give any insight into why you can't treat dependent sources as open circuits (dependent current sources), and why you can't treat dependent voltage sources as short circuits (dependent voltage sources)? I understand why it is the case for independent sources, but I just don't see why the same thinking isn't extended to dependent sources. For example, I have an example in my circuits II textbook where the Thevenin voltage is 0V at the terminals measured. The goal is to find the Thevenin resistance, but for whatever unexplained reason a test current of 1A is sent into the circuit to excite the dependent source's controlling component... why can't you read "through" them like any other source when they are deactivated; that is, when there controlling parameters are not excited. To put another way just to attempt to be more clear, if there is no input to the circuit; effectively "zeroing" the dependent sources, why can't you still read the equivalent resistance through the dependent sources like you do for ideal sources? I have not read any justification for this anywhere for this circuit analysis technique.
its pretty much by definition. An independent source is like an independent variable. You can set it to whatever you want. By setting it to zero, you make the circuit much simpler. So you calculate what the circuit when only 1 independent source is turned on at any given time, then you can add them all up according to the superposition theorem. But dependent sources, by their very definition, are essentially reactive elements that you can't just turn off.
Dependent sources are typically used as parts of a model for complicated elements such as transistors. You cannot simply set part of a model to zero, as that would break the model.
So then will it be appropriate to say then that since dependent sources are by definition reactive components, that even if there controlling elements have a zero input, by trying to measure the circuits resistance at that moment, you can't predict how the reactive components will respond by trying to measure the circuits resistance at that point?
I think you almost have it. I'm trying to be precise with my language. This is a technique meant to overall simply the circuit. So saying you 'can't' predict them is inaccurate because we are trying to quantify them. The central problem is that dependent sources are dependent on all the sources, even if they look like they are only dependent on one.
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
