Derivation of energy and angular momentum (Schwarzschild metric)
Lambda96
Derive the equations ##E= mc^2 \bigl( 1- \frac{r_s}{r} \bigr) \dot{t}## and ##l=mr^2 \dot{\varphi}##
none
Hi,
Unfortunately, I can't quite work out the terms in the task
The expression in the integral (4) corresponds to the Lagrangian and since ##t## and ##\varphi## are cyclic variables, the following follows:
$$-\frac{d}{dt} \frac{d L}{d \dot{t}}=0 \quad \rightarrow \quad -\frac{d L}{d \dot{t}}=const=E$$
$$-\frac{d}{dt} \frac{d L}{d \dot{\varphi}}=0 \quad \rightarrow \quad -\frac{d L}{d \dot{\varphi}}=const=l$$
Then I received the following:
$$\frac{d}{d \dot{t}} \Bigl( m \bigl( 1- \frac{r_s}{r} \bigr) c^2 \dot{t}^2 \Bigr)= 2m \bigl( 1- \frac{r_s}{r} \bigr) c^2 \dot{t} =E$$
$$\frac{d}{d \dot{\varphi}} \Bigl( m r^2 \dot{\varphi}^2 \Bigr)= 2m r^2 \dot{\varphi}=l$$
I get the same results except for the 2, just my question, did I do something wrong or was the 2 forgotten in the task sheet?
You simply called what is usually called ##E## by ##2E## and the same for angular momentum. If ##E## is constant, then obviously ##2E## is constant as well.
As Orodruin says, you can simply take the 2 into the definition of the constant, or not. It makes no difference to the orbits.
However, the reason for the book not having a 2 is that they've chosen their constants to match up to customary definitions. For example, instead of defining ##-dL/d\dot{t}=E## you could have used ##-dL/d\dot{t}=A## where ##A## is an unknown constant. Then you'd get to ##2m\left(1-\frac{r_s}r\right)c^2\dot{t}=A##. Now consider an orbit where the particle comes instantaneously to rest at infinity. What happens to the LHS? And hence how would you define ##A##?
Essentially, you jumped in a bit early with assuming the first constant you saw was ##E##. If you don't assume that and instead use a generic unknown constant, then you can find a case where you can write that constant in terms of what you know.
Thanks Orodruin for your help 👍, I thought I had done something wrong I hadn't thought of this simple observation :smile:
Thanks also Ibix for your help 👍
