Derivation of Statistical Mechanics
In summary: Coarse graining is a process of simplifying or averaging a system or data to make it easier to understand or analyze. It can happen naturally due to practical uncertainties, but it can also be intentionally applied by scientists in their studies.
  • #36
gentzen said:
This seems wrong to me. For the fine grained distribution to remain a probability distribution, it is enough that is remains non-negative, and follows any random continuity equation.
You're right, it's not necessarily provable that it ceases to be a probability distribution, but it may. There is only one continuity equation that is derived from the underlying physics and that's the one derived from the Schrödinger equation. It certainly won't satisfy this one.
Science news on Phys.org
  • #37
Another way to see that the use of Gibbs' H-theorem is invalid is the following: Gibbs' H-theorem really evolves every initial distribution into equilibrium. If that was reasonable, then on a macroscopic scale, everything would seem to be in equilibrium. There would be no rivers, no storms, no solar systems and so on. There would not be non-equilibrium stationary states. Gibbs' H-theorem even evolves fully integrable systems into equilibrium, which can't possibly be argued to spread over phase space.
  • #38
No, it may not. It's provable that any continuous deterministic law for velocities with any initial distribution of positions gives rise to a continuity equation.
No, Schrodinger equation alone does not imply that probability is given by ##|\psi|^2##. You must assume something more to derive that probability is equal to ##|\psi|^2##. That's, indeed, a big problem for the many-world interpretation.
  • #39
I didn't claim that though. I just claimed that Schrödinger's equation implies the continuity equation ##\partial_t|\Psi|^2+\nabla\vec j = 0## with the standard Schrödinger current ##\vec j##. It doesn't imply any other continuity equation.
  • #40
No it doesn't. It evolves most initial conditions close to equilibrium.
No it wouldn't, because time needed to come close to equilibrium can be very long. For some estimates see https://en.wikipedia.org/wiki/Heat_death_of_the_universe#Timeframe_for_heat_death
Likes dextercioby
  • #41
That's both wrong and irrelevant.
It is wrong because any other ##\vec j'## of the form
$$\vec j'=\vec j+\vec u,$$
where ##\vec j## is the standard Schrodinger current and ##\vec u## is an arbitrary vector field satisfying ##\nabla \vec u=0##, also satisfies the continuity equation ##\partial_t|\Psi|^2+\nabla\vec j' = 0##.
It is irrelevant because the continuity equation above only implies that ##\rho=|\Psi|^2## is consistent, it does not imply that ##\rho=|\Psi|^2## is necessary.
  • #42
Yes, it does. He proves that after each coarse graining step, the entropy increases, without further qualifications. Since, there is a maximum entropy, every state is evolved into a maximum entropy state and therefore into equilibrium. There are non-equlibrium stationary states, i.e. states that are invariant under the Liouville dynamics. Even those states are evolved into equilibrium by Gibbs' H-theorem. The blurring in Gibbs' H-theorem is an irreversible, entropy increasing process.
Gibbs' H-theorem evolves everything quickly into equilibrium, it's disconnected from the physical dynamics. Sure, the universe will thermalize, but not because of Gibbs' H-theorem. But even if it would take a long time, then you argument could just equally well be applied to BM to argue that the probability distribution is not given by ##|\Psi|^2## for a very long time.
  • #43
There are further qualifications. In Phys. Lett. A 156, 5 (1991), Valentini says (at the beginning of paragraph after Eq. (9)): "The proof rests on the assumption of no "micro-structure" for the initial state, as for the classical case."
  • #44
Various numerical simulations in classical and Bohmian mechanics show that (i) Gibbs equilibriation does depend on physical dynamics and (ii) equilibriation in BM is much faster due to nonlocal interactions.
  • #45
This is not a contradiction, you should have quoted the whole paragraph. He writes: "The proof rests on the assumption of no "microstructure" for the initial state, as for the classical case. Specifically, we assume the equality of coarse-grained and fine-grained quantities at the initial time t=0, i.e. we assume ##\bar P(0)=P(0), \left<|\Psi(0)|^2\right>=|\Psi(0)|^2##". This is indeed one assumption in Gibbs' proof. But it's not an assumption of the kind you were indicating. Gibbs just assumes that at ##t=0##, the coarse grained distribution is given by the fine grained distribution. But there is no further qualification on the fine grained state. Every fine grained state will be evolved into equilibrium by Gibbs' H-theorem.
Yes, Gibbs' H-theorem is a consecutive application of Liouville dynamics, then blurring, then Liouville dynamics, then blurring and so on. The Liouville dynamics is the physical input. But the blurring is an artificial, entropy increasing process. Gibbs' H-theorem evolves every state into equilibrium, independent of the physical equations of motion. The physical dynamics are there to put the correct Hamiltonian in ##e^{-\beta H}##.
Gibbs' H-theorem is always fast. The point is that Gibbs' H-theorem is unphysical, because the blurring is unphysical. The speed convergence is much faster than the actual dynamics (if there is equilibration in the actual dynamics in the first place). The universe may take ##10^100## years to thermalize, yet Gibbs' H-theorem will evolve it into equilibrium very quickly. Some systems (such as fully integrable systems) never equilibrate, yet Gibbs' H-theorem evolves them into equilibrium nevertheless. This just shows that Gibbs' H-theorem is inappropriate to decide whether something evolves into equilibrium or not.
  • #46
I have already explained that blurring does not work that way. I used analogy with a strong computer and a low resolution screen.
  • #47
Blurring in Gibbs' H-theorem works this way.
  • #48
Can you give a reference?
  • #49
See any proof of Gibbs' H-theorem, e.g. Tolman "Principles of Statistical Mechanics".
  • #50
I'm looking at Sec. 51 devoted to the Gibbs generalization of the Boltzmann's H-theorem. In this section I cannot find any confirmation of your claims. Can you be more specific by giving the exact page and/or exact quote?
  • #51
He starts with a fine grained distribution ##\rho_1## and a distribution ##\P_1=\rho_1##. He then evolves both using Liouville dynamics. ##\rho_1## evolves into ##\rho_2##. ##P_2## arises by evolving ##P_1## using Liouville's dynamics and then restricting it to a coarse grained phase space. He shows that ##\rho_2\neq P_2## in eq. (51.16). He shows that the entropy of the coarse grained distribution increased in eq. (51.20). The entropy of the fine grained distribution remains constant (obviously, because Liouville dynamics is reversible). He then says that further time evolution of this kind will further increase the entropy of the coarse grained state at the end of p. 172, i.e. the the state needs to be evolved and coarse grained again in order to further increase entropy until ##S_{max}## is reached.
  • #52
So far so good.
Nullstein said:
He then says that further time evolution of this kind will further increase the entropy of the coarse grained state at the end of p. 172, i.e. the state needs to be evolved and coarse grained again in order to further increase entropy until ##S_{max}## is reached.
The crucial question here is what one means by "the state". In my understanding it is the fine grained state (that is evolved and coarse grained again), while in your understanding it is the coarse grained state (that is evolved and coarse grained again). The text of Tolman does not seem explicit about that. Your understanding requires the coarse graining to be physical, while my understanding only requires a lack of information about the fine grained state. Tolman says that it "corresponds to a decrease with time in the definite character of our information" which indicates that his understanding coincides with mine, not with yours.
  • #53
Your understanding can be proven to be wrong quite easily: Suppose ##\rho_1## is a delta state, then its coarse grained version is just a uniform distribution over the phase cell where the system is located. The time evolution of this state will again be a delta state and its coarse gaining will again be a uniform distribution in a (different) phase cell. The entropy of a uniform distribution in a phase cell is given by some constant and depends only on the size of the phase cell, not on its location. Therefore, the entropy will not increase according to your understanding. And since a uniform distribution on a phase cell is not a thermal state, your version of this process won't evolve the state into an equilibrium and ##S_{max}## will never be reached. Your version of this process will only make the particle from one phase cell into another in the coarse grained picture. It will never spread across multiple phase cells.
  • #54
But the size of the phase cell the fine-grained "delta" state is in does depend on its location--as the fine-grained "delta state" evolves in time, it moves into different phase cells with different sizes--and those sizes are overwhelmingly likely to be larger than the size of the original phase cell. That's why the entropy increases (or more precisely is overwhelmingly likely to increase).
  • #55
Not true. The phase cells are all of the size ##\delta q\delta p\ldots## with some fixed lengths ##\delta q##, ##\delta p##. It's just a lattice version of phase space with a fixed lattice spacing.
  • #56
Who said it would?
  • #57
PeterDonis said:
Who said it would?
Demystifier. At least if he claims that the state approaches a thermal state. The coarsed grained version of ##e^{-\beta H}## certainly has contributions in all phase cells where ##H\neq\infty##.
  • #58
I have no idea where you are getting this from. Coarse graining in thermodynamics means each phase space "cell" consists of all phase space points that correspond to the same values (or more precisely functions) for all macroscopic thermodynamic variables. Those cells will not all be the same size.
  • #59
Read the book that I cited.
Coarse graining in Gibbs' H-theorem means projecting the fine grained state on a lattice version of phase space with fixed sized phase cells. Again, please read the book (specifically eq. (51.3)).
  • #60
It's true for the delta state, but not true for most other fine grained states.
Anyway, I have checked also the book by Jancel, "Foundations of Classical and Quantum Statistical Mechanics", Sec. "Discussion of the generalised H-theorem" starting at page 169. He starts with "It can be seen from the foregoing developments that this theorem is obtained without any special assumptions, except the fundamental assumption of statistical mechanics, which is necessary for the statistical description of macroscopic phenomena and which cannot contradict the reversibility of the laws of mechanics." Likewise, the section ends with: "... the evolution takes place according to the deterministic laws of mechanics, the irreversibility arising from the gross nature of our observations. Thus, it is not possible to have any kind of contradiction between the statistical conclusions of the theory and the reversible behaviour of mechanical systems." I think it contradicts your view.
  • #61
In classical physics, isn't any fine-grained state a delta function in phase space (i.e., a single phase space point)?
Likes vanhees71
  • #62
First of all, the delta state is the physically most relevant case, since arguably, a true physical system is always in such a pure state, independent of what we know about it. Thus, the argument that the thermal state arises as a coarse graining of the true physical state in the way you imagine, is already falsified.
But moreover, you are just making a claim without proof here. How do you know that the situation is better for other states? Gibbs' H-theorem certainly won't help here. Let's just recapitulate what Gibbs' H-theorem says and what is doesn't say:
  1. Gibbs' H-theorem says the following: The entropy of the coarse grained version of a time evolved state is greater than the entropy of the time evolved state itself. This is the content of equation (51.20), Gibbs' H-theorem.
  2. Gibbs' H-theorem does not claim that the entropy of the coarse grained state at later time is greater than the entropy of the coarsed grained state at earlier time. That's just not the content of the theorem.
If you apply Gibbs' H-theorem once, it only allows you to say that the coarse grained state has higher entropy than the fine grained state. You can't use the theorem to conclude that the entropy of the coarse grained version of the fine grained state increases over time. And one application of the theorem is not enough either, because it doesn't state that the coarse grained state has maximum entropy.
In order to use Gibbs' H-theorem to argue for an approach of equilibrium, you must argue the theorem consecutively, i.e. there must be a time evolution, then a coarse graining, then a time evolution, then a coarse graining and so on. Only in this situation, you get an increase of entropy at every step and you will get a convergence towards the highest entropy state, which is a thermal state.
This is just prose. The book contains the exact same math as Tolman, so the above arguments apply here as well. A single level of coarse graining is not enough to conclude an increase of entropy to ##S_{max}##. The only thing that you can conlcude is that at all times, the entropy of the coarse grained state is higher than the entropy of the fine grained state. No relation between the entropies of coarse grained states at different times is implied.
  • #63
Not in classical statistical physics. That's why we have phase-space distributions. Fine grained distribution is defined on a continuous phase space, while in the coarse grained distribution the phase space is divided into finite cells.
Likes vanhees71
  • #64
@Nullstein, is there a peer-reviewed paper, or a book, that explicitly agrees with you in saying that Gibbs H-theorem does not work for the reasons you are explaining here? If not, do you consider the possibility to write a paper by yourself?
Likes vanhees71
  • #65
Also in statistical physics, the fine grained distribution is a delta distribution. The idea of statistical physics is to derive macroscopic properties from the microscopic details. The microscopic theory doesn't suddenly change just because we want to compute macroscopic observables. The ontology of classical mechanics as crystal clear: Every particle has one position and one position only (similarly for momentum). This must be the starting point for every proper derivation of statistical physics.
Also, since we are talking about applications to Bohmian mechanics here: The ability to resolve the measurement problem crucially depends on the fact that Bohmian particles have a single true trajectory. If you don't have this, then you can't explain why only one branch of the wave function is realized.
The very book you quoted agrees with me:
And you can also read that the statement that I have made: You can only conclude that the coarse grained entropy at later time is higher than the coarse grained entropy at the initial time (##\bar H(t)\leq\bar H(0)##):
You cannot assert that ##\bar H(t_3)\leq\bar H(t_2)## (for ##t_3>t_2>t_1=0##), because you would need to assume that ##P(t_2) = \rho(t_2)## for that:
This can't be true in this situation, because
If you want to use the theorem to assert that ##\bar H(t_3)\leq\bar H(t_2)##, you must thus perform another coarse graining step in order to obtain ##P(t_2) = \rho(t_2)##, so the assumptions of the theorem are fulfilled again.
Therefore, unless there is intermediate coarse graining, the theorem says nothing about convergence to equilibrium.
In fact, the book you cited actually supports my view of how statistical mechanics emerges, namely from the ergodic hypothesis:
Likes jbergman
  • #66
@Nullstein I think that your claims against Gibbs H-theorem are much stronger than those quotes. In other words, I don't think that those quotes confirm those of your claims with which I disagree. But anyway, I think that at this point we can agree to disagree and conclude this discussion.
  • #67
I don't think my claims are stronger. I just agree with the author of that book that Gibbs' H-theorem can't be used to derive the statistical equilibrium distribution. He makes this clear in multiple places throughout the chapter, I only quoted a fraction of them. The author wrote the exact same things as I did. Also my post #56 is an easily understandable proof with a concrete, physically relevant example that shows that it can't work. I don't think there is room to agree to disagree, because it is not possible for someone who has internalized the arguments, to disagree. There is no vagueness in this argument, all of this is exact mathematics. Also, I am convinced that this is really standard knowledge and I'm not making any claim beyond that which is taught in a standard course on statistical physics.
  • #68
I have gone through the book in some detail now. I see where I was misunderstanding the "coarse graining" terminology as it is used in the book (I am used to seeing that term used differently): as the book uses the term, the size of the phase space cells is fixed, yes.
However, I don't see anything in the book that justifies this claim of yours:
The only distributions that are even considered in the book with regard to the Gibbs H-theorem are distributions in which the fine grained state ##\rho## is a uniform distribution in each finite coarse-grained phase space cell (the value of ##\rho## can vary from cell to cell, but it is uniform over each individual cell). The basic argument given in the book is that if we start with an ensemble that is uniformly distributed over a single phase space cell (which is what justifies the initial condition ##\rho = P##), the time evolution of that ensemble will not be uniformly distributed over a single phase space cell (so we will have ##\rho \neq P## at the later time, which is what leads to the conclusion that the Gibbs ##H## decreases).
  • #69
I don't think that's true. Can you cite where in the book that the distribution is uniform in each cell?
What I read was is that ##P## is equal to the average of ##\rho## over a cell.
However as ##\rho## evolves that original volume changes shape and no longer matches our coarse-graining grid so that at a later time ##P## is no longer equal to the average of ##\rho## over a coarse grained cell.
  • #70
Page 170, in the paragraph above equation 51.14:
"Since the fine-grained density ##\rho## will have a constant value inside each such region..."
Note carefully that I did not say that all possible distributions have ##\rho## constant in each phase space cell (which is what "each such region" in the above quote refers to). I only said that, in the proof of the Gibbs H-theorem, Tolman only considers such distributions. And that is what he is doing in the quote above.
Likes vanhees71 and jbergman
12K
