I Derivation of the Helmholtz equation
The Helmholtz equation is derived as the time-independent form of the wave equation, which can be expressed using the Fourier transform. The discussion highlights the differentiation properties of the Fourier transform, leading to the conclusion that the Helmholtz equation can be represented as a member of a larger set of equations. Specifically, by setting the second derivative in the spatial domain, the Helmholtz equation emerges from the wave equation. The conversation also addresses the complexities introduced by different conventions, such as the use of factors of 2π and the representation of wave frequencies. Overall, the derivation process and the relationship between the wave equation and the Helmholtz equation are central to the discussion.
redtree
TL;DR Summary
Derivation from the Fourier transform
I am trying to understand the Helmholtz equation, where the Helmholtz equation can be considered as the time-independent form of the wave equation. It seems to me that the Helmholtz equation can be derived from the Fourier transform, such that it is part of a larger set of equations of varying order.
Given a differentiable function ##f(\vec{x})##, I note the differentiation property of the Fourier transform,
\begin{equation}
\begin{split}
\partial_{\vec{x}} f(\vec{x}) &= \partial_{\vec{x}} \int_{\mathbb{R}} e^{2 \pi i \vec{k} \cdot \vec{x}} \hat{f}(\vec{k}) d\vec{k}
&= \int_{\mathbb{R}} \partial_{\vec{x}} e^{2 \pi i \vec{k} \cdot \vec{x}} \hat{f}(\vec{k}) d\vec{k}
&= \int_{\mathbb{R}} 2 \pi i \vec{k} e^{2 \pi i \vec{k} \cdot \vec{x}} \hat{f}(\vec{k}) d\vec{k}
&= \mathscr{F}^{-1} \left[2 \pi i \vec{k} \hat{f}(\vec{k}) \right]
\end{split}
\end{equation}
The converse is also true, such that
\begin{equation}
\begin{split}
2 \pi i \vec{k} \hat{f}(\vec{k}) &= \mathscr{F}\left[\partial_{\vec{x}} f(\vec{x}) \right]
&= \int_{\mathbb{R}} e^{-2 \pi i \vec{k} \cdot \vec{x}} \bigg( \partial_{\vec{x}} f(\vec{x}) \bigg) d\vec{x}
\end{split}
\end{equation}
Regarding ##2 \pi i \vec{k} \hat{f}(\vec{k})##, I also note the following:
\begin{equation}
\begin{split}
2 \pi i \vec{k} \hat{f}(\vec{k}) &= 2 \pi i \vec{k} \mathscr{F}\left[f(\vec{x}) \right]
&= 2 \pi i \vec{k} \int_{\mathbb{R}} e^{-2 \pi i \vec{k} \cdot \vec{x}} f(\vec{x}) d\vec{x}
&= \int_{\mathbb{R}} e^{-2 \pi i \vec{k} \cdot \vec{x}} \bigg( 2 \pi i \vec{k} f(\vec{x}) \bigg) d\vec{x}
\end{split}
\end{equation}Combining these last two equations,
\begin{equation}
\begin{split}
\int_{\mathbb{R}} e^{-2 \pi i \vec{k} \cdot \vec{x}} \bigg( \partial_{\vec{x}} f(\vec{x}) \bigg) d\vec{x}&= \int_{\mathbb{R}} e^{-2 \pi i \vec{k} \cdot \vec{x}} \bigg( 2 \pi i \vec{k} f(\vec{x}) \bigg) d\vec{x}
\end{split}
\end{equation}
which simplifies to
\begin{equation}
\begin{split}
\vec{k} f(\vec{x}) &= -\frac{i}{(2 \pi) } \partial_{\vec{x}} f(\vec{x})
\end{split}
\end{equation}
This same holds true for any ##n##-th derivative, such that
\begin{equation}
\begin{split}
\big(\vec{k} \big)^n f(\vec{x}) &= \left(-\frac{i}{2 \pi} \right)^n \big(\partial_{\vec{x}} \big)^n f(\vec{x})
\end{split}
\end{equation}
Setting ##n=2## produces the Helmholtz equation
\begin{equation}
\begin{split}
\big( \vec{k} \big)^2 f(\vec{x}) &= -\frac{1}{(2 \pi)^2} \big( \partial_{\vec{x}} \big)^2 f(\vec{x})
\end{split}
\end{equation}
which would make the Helmholtz equation the member of order ##n=2## of a larger set of Helmholtz-type equations
That's a bit complicated. Just start from the wave equation for some field ##\Phi(t,\vec{x})##
$$\left (\frac{1}{c^2} \partial_t^2 - \Delta \right) \Phi(t,\vec{x})=0.$$
Here ##c## is the phase velocity of the waves.
Now we express the field as a Fourier integral with respect to time. Using the HEP physicists convention concerning the factors ##2 \pi## and the sign in the exponential this reads
$$\Phi(t,\vec{x})=\int_{\mathbb{R}} \mathrm{d} \omega \frac{1}{2 \pi} \tilde{\Phi}(\omega,\vec{x}) \exp(-\mathrm{i} \omega t) \; \Leftrightarrow \; \tilde{\Phi}(\omega,\vec{x}) = \int_{\mathbb{R}} \mathrm{d} t \tilde{\Phi}(\omega) \exp(+\mathrm{i} \omega t).$$
Now plug the first form of the Fourier transformation into the wave equation (just assuming you can integrate under the integral)
$$\left (\frac{1}{c^2} \partial_t^2 - \Delta \right) \Phi(t,\vec{x})=\int_{\mathbb{R}} \mathrm{d} \omega \frac{1}{2 \pi} (-k^2-\Delta) \tilde{\phi}(\omega,\vec{x})=0 \; \Rightarrow \; (k^2+\Delta) \tilde{\Phi}(\omega,\vec{x})=0.$$
Here ##k=\omega/c##, and that's the Helmholtz equation.
Likes Delta2 and ergospherical
I rewrite the derivation you cite in slightly different notation as follows:
\begin{equation}
\begin{split}
\Phi(x_0,\vec{x}_3) &= \int_{\mathbb{R}} \hat{\phi}(k_0,\vec{x}_3) e^{- 2 \pi i k_0 x_0} dk_0
\end{split}
\end{equation}
where ##\vec{x}_4 = [x_0, x_1, x_2, x_3] = [x_0, \vec{x}_3]## and ##\vec{k}_4 = [k_0, k_1, k_2, k_3] = [k_0, \vec{k}_3]##
Given the wave equation:
\begin{equation}
\begin{split}
\bigg(\partial_{x_0}^2 - \partial_{\vec{x}_3}^2 \bigg) \Phi(x_0,\vec{x}_3) &= 0
\end{split}
\end{equation}
where ##\partial_{x_0} = \partial_t## and ##\partial_{\vec{x}_3}^2 = \Delta##
Combining the two equations
\begin{equation}
\begin{split}
\bigg(\partial_{x_0}^2 - \partial_{\vec{x}_3}^2 \bigg) \Phi(x_0,\vec{x}_3) &= \bigg(\partial_{x_0}^2 - \partial_{\vec{x}_3}^2 \bigg) \int_{\mathbb{R}} \hat{\phi}(k_0,\vec{x}_3) e^{- 2 \pi i k_0 x_0} dk_0
&= \bigg(\left(2 \pi k_0\right)^2 - \partial_{\vec{x}_3}^2 \bigg) \hat{\Phi}(k_0,\vec{x}_3)
&= 0
\end{split}
\end{equation}
which I summarize:
\begin{equation}
\begin{split}
\bigg(\left(2 \pi k_0\right)^2 - \partial_{\vec{x}_3}^2 \bigg) \hat{\Phi}(k_0,\vec{x}_3) &= 0
\end{split}
\end{equation}
Comparing this to the equation I derived (in similar notation)
\begin{equation}
\begin{split}
\bigg( \left(2 \pi \vec{k}_3\right)^2 - \partial_{\vec{x}_3}^2 \bigg) \Phi(\vec{x}_3) &= 0
\end{split}
\end{equation}
Thus, the equation I derived above is different from the Helmholtz equation. I get it. Thanks. Is there a name for the equation I derived. It seems correct. I don't see a mistake in its derivation. Am I missing something?
You forget the factor ##\mathrm{i}^2=-1## from the two time-derivatives! BTW it's very complicated to introduce the ##2 \pi## in the exponent and working with ##\nu## instead of ##\omega##. I've seen only one textbook (Weizel, Lehrbuch der Theoretischen Physik, an otherwise excellent textbook, but as far as I know not available in English), where this is done, and you suffer from a lot of factors ##2 \pi##.
vanhees71 do you mind going through all the relevant steps after plugging in the first form of the Fourier transformation into the wave equation? I don't understand how to reach the final form of the Helmholtz equation. Your help would be greatly appreciated.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
