I Derivation of two-electron density operator
Mart1234
TL;DR Summary
Derivation of two electron density operator using single electron density operator
Hello, I am going over the derivation for two-electron density. I am having a hard time understanding how the second term in 2.11a seen below is derived. I know this term must eliminate the i=j products but can't seem to understand how. Thanks for the help.
Where is this coming from? The 2nd equality of (2.11a) seems to indicate that you consider a special state of uncorrelated/free particles, but we need more context to make sense of it.
I've never seen the two-electron density written like that. Here are my thoughts but I can't say for sure.
Considering the terms where ##i=j## $$\sum_{i}\delta(\mathbf r-\mathbf r_i)\delta(\mathbf r' - \mathbf r_i)$$We should be able to use the identities ##\delta(x - y) = \delta(y - x)## and ##\int dy \delta(x-y)\delta(y-x') = \delta(x-x')## So we rewrite the above as $$\sum_{i}\delta(\mathbf r-\mathbf r_i)\delta(\mathbf r_i - \mathbf r')$$ and when we are computing the electron density function we will be integrating over ##\mathbf r_i## so the latter identity suggests $$\sum_i\int d\mathbf r_1\dots d\mathbf r_N \delta(\mathbf r - \mathbf r_i)\delta(\mathbf r_i - \mathbf r')|\Psi(\mathbf r_1,\dots, \mathbf r_N)|^2 = N\int d\mathbf r_2\dots d\mathbf r_N \delta(\mathbf r - \mathbf r')|\Psi(\mathbf r,\dots, \mathbf r_N)|^2$$For the last line. I am assuming $$\int dx\int dy \delta(x-y)\delta(y-x')f(y) = \int dx \delta(x-x')f(x)$$
Morbert said:
I've never seen the two-electron density written like that. Here are my thoughts but I can't say for sure.Considering the terms where ##i=j## $$\sum_{i}\delta(\mathbf r-\mathbf r_i)\delta(\mathbf r' - \mathbf r_i)$$We should be able to use the identities ##\delta(x - y) = \delta(y - x)## and ##\int dy \delta(x-y)\delta(y-x') = \delta(x-x')## So we rewrite the above as $$\sum_{i}\delta(\mathbf r-\mathbf r_i)\delta(\mathbf r_i - \mathbf r')$$ and when we are computing the electron density function we will be integrating over ##\mathbf r_i## so the latter identity suggests $$\sum_i\int d\mathbf r_1\dots d\mathbf r_N \delta(\mathbf r - \mathbf r_i)\delta(\mathbf r_i - \mathbf r')|\Psi(\mathbf r_1,\dots, \mathbf r_N)|^2 = N\int d\mathbf r_2\dots d\mathbf r_N \delta(\mathbf r - \mathbf r')|\Psi(\mathbf r,\dots, \mathbf r_N)|^2$$For the last line. I am assuming $$\int dx\int dy \delta(x-y)\delta(y-x')f(y) = \int dx \delta(x-x')f(x)$$
Got it. I appreciate the help.
We often see discussions about what QM and QFT mean, but hardly anything on just how fundamental they are to much of physics. To rectify that, see the following; https://www.cambridge.org/engage/api-gateway/coe/assets/orp/resource/item/66a6a6005101a2ffa86cdd48/original/a-derivation-of-maxwell-s-equations-from-first-principles.pdf 'Somewhat magically, if one then applies local gauge invariance to the Dirac Lagrangian, a field appears, and from this field it is possible to derive Maxwell’s...
I read Hanbury Brown and Twiss's experiment is using one beam but split into two to test their correlation. It said the traditional correlation test were using two beams........ This confused me, sorry. All the correlation tests I learnt such as Stern-Gerlash are using one beam? (Sorry if I am wrong) I was also told traditional interferometers are concerning about amplitude but Hanbury Brown and Twiss were concerning about intensity? Isn't the square of amplitude is the intensity? Please...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
