Derivative not correct for online hw submission, but is correct
  • Thread starter Thread starter Torshi
    Derivative
Torshi
Find the d/dx
(x^2+2x+5)^2
Chain rule
My answer:
2(x^2+2x+5)*(2x+2)*2
Why did you apply the chain rule again to (2x+2)? You only need to do it once.
It should be:
##2(x^2 + 2x + 5)(2x + 2)##
Think of it this way: ##f(x) = x^2## and ##g(x) = x^2 + 2x + 5##.
Then, ##D(f \circ g)(x) = Df(g(x))D(g(x))##
You could also just multiply it out and use the power rule.
Torshi, your title is misleading. The derivative you show is not correct for online submission, AND it is not correct, as Karnage1993 points out.
I didn't mean it to be misleading. My fault. The reason why I said that was because I was at my university math lab and even one of the math instructors said it was correct, but made a tad mistake until I mentioned it. I figured out the answer though.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
