Derivative of a function of a function - .
In summary, the professor is discussing Newtonian mechanics and explaining that if dv/dt = a, then v*dv/dt is equal to a*v. He then shows that this is the same as d(v^2/2)/dt and uses the rule d/dg(g^2/2) = g to explain it. The student is having trouble understanding how the chain rule applies in this example.
christian0710
409
Hi at 1 Hour and 9 minutes this professor makes a derivation which i do not understand
He is lecturing on Newtonian mechanics and states that if
dv/dt = a (acceleration)
Then
v*dv/dt = a*v
And then he says that this is the same as
d(v^2/2)/dt
But I just can't undrestand how he did that last part? I know how to apply the chain rule to the derivative of a funnction of a function but i can't see how this applies in this example. The form he writes it on is f(x)*d(f(x)/dx (the same as v*dv/dt ) and the chain rule is on the form df(g(x))/dx = df(g)/dg * d(g(x))/dx? did he write it in a wrong mathematical form? What rule is he using?
If you work it backward you get what he started with right?
ie d( x^2) / dx = 2x and so 1/2 d( x^2 ) = x
let u = v^2
then du/dt = 2v dv/dt right?
All he says is ##{d\over dt} \left (v^2/2\right ) = v {dv\over dt}## right ?
the rule he is using is that d/dg (g2/2) = g !
if f = g2/2 and g = v your chain rule also says df/dg = g and df/dt = g dg/dt , in other words d/dt(v2 /2) = v dv/dt
Related to Derivative of a function of a function - .
1. What is the chain rule and how does it apply to finding the derivative of a function of a function?
The chain rule is a formula used to find the derivative of a composite function, where the input of one function is used as the input of another function. It states that the derivative of a composite function f(g(x)) is equal to the derivative of the outer function f'(g(x)) multiplied by the derivative of the inner function g'(x). In other words, it allows us to find the rate of change of a function within a function.
2. Can the chain rule be applied to all functions of functions?
Yes, the chain rule can be applied to any composite function, regardless of the complexity of the inner and outer functions. It is a fundamental rule in calculus and is used extensively in finding derivatives of a wide range of functions.
3. How does the chain rule relate to the power, product, and quotient rules?
The chain rule is a combination of the power, product, and quotient rules. It is essentially a combination of these three rules applied in a specific way to find the derivative of a composite function. It is often used in conjunction with these rules to find derivatives of more complex functions.
4. What are some practical applications of the chain rule?
The chain rule has many practical applications in fields such as physics, economics, and engineering. It is used to find the rate of change of a function within a function, which is useful in determining things like velocity, acceleration, and optimization problems. It is also used in financial analysis to calculate the marginal cost and revenue functions.
5. Are there any common mistakes or misconceptions when using the chain rule?
One common mistake is forgetting to apply the chain rule when taking the derivative of a composite function. It is important to remember to multiply by the derivative of the inner function in addition to applying the power, product, and quotient rules. Another misconception is that the chain rule only applies to functions with two levels of composition, but it can be applied to functions with any number of levels of composition.
