Derivative of inverse trig function absolute value?
quark001
Find the derivative of y = arctan(x^(1/2)).
Using the fact that the derivative of arctanx = 1/(1+x^2) I got:
dy/dx = 1/(1+abs(x)) * (1/2)x^(-1/2)
But my textbook gives it without the absolute value sign. I don't understand why because surely x^(1/2) squared is the absolute value of x and not simply x?
x^(1/2) is well-defined for positive x only (unless you work with complex numbers). If you don't have any negative numbers, ...
you have to consider the signs of the trigo identities
Oh okay. The function is undefined for negative x to begin with... Stupid question.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
