Derivative of (sin(sin(sin(x))))
  • Thread starter Thread starter Torshi
    Derivative
Torshi
Derivative of d/dx (sin(sin(sin(x))))
Chain Rule twice?
d/dx Cos(sin(sin(x)))) * Cos(sin(x)) * Cos(x)
yes use the chain rule:
f(x)=sin(sin(x))
df/dx = cos(sin(x)) * cos(x)
your solution looks correct.
f(x)=sin(sin(x))
Well the original problem was f(x) = (sin(sin(sin(x)))), but yes I believe I got it right. Thank you.
I know that but at first I didn't want to give you the answer outright. Later as I reread your post I saw that you had in fact the right answer. Anyway, its helpful to see a simpler example.
Oh alrighty! Yea, when I saw the problem I was unsure at first, but then I thought I should do the chain rule. Wasn't too bad now that I think of it. Just wanted to make sure. Thanks!
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
