Derivative of the kinetic energy
Taking the derivative of kinetic energy with respect to velocity results in momentum, as shown by the equation K = 0.5mv^2. The derivative dK/dv simplifies to mv, which aligns with the definition of momentum (p = mv). The discussion highlights the connection between kinetic energy and momentum through calculus concepts. The user confirms that their understanding of derivatives is limited, but they correctly identify momentum as the answer. Overall, the relationship between kinetic energy and momentum is clarified through derivative calculations.
watsup91749
Derivative of the kinetic energy...
If you take the derivative of the kinetic energy of a particle with respect to its velocity you get...
A) force
B) momentum
C) acceleration
D) mass
E) potential energy
K= .5mv^2
Im in pre calc right now and i have no idea how to take the derivative of anything, quick google searching led me to believe that its a calculus thing, so it would be really helpfull if someone could explain how to do this..
If you have
y=kx^n
and you want to find the derivative of that with respect to x,denoted as \frac{dy}{dx}
it is simply
\frac{dy}{dx}=knx^{n-1}Where k is a constant
I think the answer is B momentum, is that right? momentum has p=mv and kinetic energy has the same variables, so it must be B right?
Also K=mv^(2-1) would be the same as K=mv which is the the same as momentum, is this correct?
\frac{dK}{dv}=mv which is momentum so you are correct.
You could also exploit the notation and think about it in terms of units.
dK/dv = [\frac{kg * m^2/s^2}{m/s}] = [kg * m/s]
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
