Deriving Entropy Formula: Thermo Solution
  • Thread starter Thread starter olechka722
    Derivation Thermo
The discussion centers on deriving an entropy formula from the equation dS = Cv/T dT + R/(V-b) dV. The initial query expresses confusion about integrating the two terms due to the presence of differentials. A participant clarifies that the terms can be integrated separately since they represent partial derivatives, with Cv being the heat capacity at constant volume. However, another contributor points out that simply recognizing the terms as partial derivatives is not enough; it is essential to consider that Cv may depend on both temperature and volume. The conversation highlights the complexities involved in integrating thermodynamic equations accurately.
olechka722
Hello,
I am trying to derive a formula for entropy. I have:
dS= Cv/T dT + R/(V-b) dV
and want to get:
S= Cv*ln(T) + R*ln(V-b) + constant.
Math rules seem to say i can't just integrate this up even though it looks obvious since i have two different d's on the right hand side. Maybe something using Maxwell relations? Not sure.
Thank you for any help!
olechka
Science news on Phys.org
The first term on the right side contains only a constant, a function of T, and dT. The second term contains only constants, a function of V, and dV. It's OK to integrate the terms separately in this case. You can verify this by differentiating the second expression.
You can just integrate it up I believe. The derivatives in this instance are actually partial derivates if I am not mistaken (the evidence is that Cv is the heat capacity at constant V...which implies that the second term is the change due to volume at constant T). So the total change in S is the sum of the integration of the two partial derivatives.
Not quite. It's true that the terms represent partial derivatives; that is, we're looking at
dS=\left(\frac{\partial S}{\partial T}\right)_V dT+\left(\frac{\partial S}{\partial V}\right)_T dV
However, this observation isn't sufficient to conclude that the integral of the right hand side equals the sum of the integrals of the individual terms. We must also require that C_V(T,V)=T\left(\frac{\partial S(T,V)}{\partial T}\right)_V, which is generally a function of both T and V, is idealized as a constant, as I stated above.
Been around 40 years since I took basic physics in college and while I remember doing some examples of insulation values / energy conduction, I doubt I could to the math now even if I could find the formulas. I have some some corrugated plastic sheet (think of the plastic signs you see on the side of the road) that is used in bee hives. Also have some used in a green house though a bit different in dimensions than this example but the general approach should still apply. Typically, both...
Problem: You’re an Uber driver with a Tesla Model 3. Today’s low: 30F, high: 65F. You want to reach a USD$ profit target in the least number of hours, but your choices could have added cost. Do you preheat the battery only when you are headed to the charging station (to increase the charging rate by warming the battery — however the battery might not be “warm enough” when your reach the charger and thus slower charging rates), or do you always “navigate to the charger” the entire day (which...
Thread 'Is Callen right in claiming dQ=TdS for all quasi-static processes?'
Hello! I am currently reading the second edition of Callen's Thermodynamics and an Introduction to Thermostatistics, and I have a question regarding Callen's definition of quasi-static. On page 96, Callen says: Another way of characterizing Callen's definition is that a process is quasi-static if it traces out a continuous curve in the system's configuration space. So far it's all well and good. A little later, Callen claims that the identification of $$TdS$$ as the heat transfer is only...
